Ir para o conteúdo principal
Steam Deck Right Trigger Replacement
O que você precisa
  1. Steam Deck Right Trigger Replacement, Prepare your Steam Deck for disassembly: passo 1, imagem 1 %32 Steam Deck Right Trigger Replacement, Prepare your Steam Deck for disassembly: passo 1, imagem 2 %32 Steam Deck Right Trigger Replacement, Prepare your Steam Deck for disassembly: passo 1, imagem 3 %32
    • Turn on your Steam Deck and allow the battery to discharge below 25% before starting your repairs, as a charged lithium-ion polymer battery can be dangerous if accidentally punctured.
    • As an extra precaution, Valve recommends putting your Steam Deck into battery storage mode within the BIOS before starting any internal repairs. Read how to do that here.
    • Power down your Steam Deck and unplug any cables.
    • If you have a microSD card installed, make sure to remove it before opening the Steam Deck. If you attempt to remove the back cover with it still installed, it could snap right in half.
    • During your repair, it can be helpful at times to lay the Steam Deck face-down into its case to protect the thumbsticks and prevent wobble.
  2. Steam Deck Right Trigger Replacement, Remove the back cover screws: passo 2, imagem 1 %32
    Ferramenta utilizada neste passo:
    FixMat
    $36.95
    • Use a Phillips driver to remove the eight screws securing the back cover:
    • Four coarse thread 9.5 mm-long screws
    • Four fine thread 5.8 mm-long screws
    • Despite the standards, Phillips screwdrivers can vary in size and shape—two drivers labeled as the same size may fit differently in the same screw. Use the size that fits the snuggest into the screw head.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your Steam Deck.
  3. Steam Deck Right Trigger Replacement, Unclip the back cover: passo 3, imagem 1 %32 Steam Deck Right Trigger Replacement, Unclip the back cover: passo 3, imagem 2 %32
    • Insert an opening pick into the thin gap between the back cover and the front shell, along the edge of the right grip.
    • If you're having trouble inserting your pick at the grip seam, try starting at either the top or bottom long edges first, then slide the pick towards the grip.
    • Pry up on the back cover to release it from the locking clips.
  4. Steam Deck Right Trigger Replacement, Remove the back cover: passo 4, imagem 1 %32 Steam Deck Right Trigger Replacement, Remove the back cover: passo 4, imagem 2 %32 Steam Deck Right Trigger Replacement, Remove the back cover: passo 4, imagem 3 %32
    • Once the clips are disconnected from one edge, the rest disconnect easily.
    • Grip the back cover at the opening you just created and pull it up and away from the device to unclip the long edges.
    • Remove the back cover.
  5. Steam Deck Right Trigger Replacement, Uncover the hidden shield screw: passo 5, imagem 1 %32 Steam Deck Right Trigger Replacement, Uncover the hidden shield screw: passo 5, imagem 2 %32
    • If you have a refreshed Steam Deck version with the black motherboard cover, skip this step.
    • Use a pair of tweezers to remove the piece of foil tape covering the hidden screw on the board shield.
    • If possible, try not to rip or tear this tape so it can be reused. If necessary, you can fashion a replacement by cutting a piece of aluminum foil tape to fit.
  6. Steam Deck Right Trigger Replacement, Remove the shield screws: passo 6, imagem 1 %32 Steam Deck Right Trigger Replacement, Remove the shield screws: passo 6, imagem 2 %32
    • Use a Phillips driver to remove the three screws securing the board shield:
    • One 3.4 mm screw
    • Two 3.7 mm screws
    • Only the two 3.7 mm screws along the left edge are present in refreshed Steam Decks.
  7. Steam Deck Right Trigger Replacement, Remove the shield: passo 7, imagem 1 %32 Steam Deck Right Trigger Replacement, Remove the shield: passo 7, imagem 2 %32 Steam Deck Right Trigger Replacement, Remove the shield: passo 7, imagem 3 %32
    • Remove the board shield.
    • Depending on the age of your Steam Deck, this shield may stick to the thermal pads underneath.
    • During reassembly, ensure that the fan cable lays on the side of the board shield and isn't pinched underneath.
  8. Steam Deck Right Trigger Replacement, Disconnect the battery: passo 8, imagem 1 %32 Steam Deck Right Trigger Replacement, Disconnect the battery: passo 8, imagem 2 %32 Steam Deck Right Trigger Replacement, Disconnect the battery: passo 8, imagem 3 %32
    • Grip the battery cable by its pull tab and pull it directly away from the motherboard to disconnect it.
    • Alternatively, use the flat end of a spudger or a clean fingernail to gently push the connector out of its socket, then disconnect it completely by hand.
  9. Steam Deck Right Trigger Replacement, Unclip the right trigger: passo 9, imagem 1 %32 Steam Deck Right Trigger Replacement, Unclip the right trigger: passo 9, imagem 2 %32
    • The right trigger will be on your left-hand side when working on the Steam Deck, as it's laying upside down.
    • The Steam Deck's triggers clip into place on two pegs on the trigger bracket, which doubles as the hinge.
    • Place the flat end of a spudger onto the inside edge of the trigger's right clip.
    • Pivot the trigger clip out, away, and up from the peg to unlatch it.
    • During reassembly, latch the outermost peg first. Once in place, push down on the trigger to latch the innermost peg, producing an audible "click" sound.
    • Check to make sure that the trigger spring is properly aligned. Test the trigger action before continuing reassembly.
  10. Steam Deck Right Trigger Replacement, Remove the right trigger: passo 10, imagem 1 %32 Steam Deck Right Trigger Replacement, Remove the right trigger: passo 10, imagem 2 %32
    • Remove the right trigger.
    • Take care to not lose the trigger spring. It press-fits onto a peg on the trigger's underside.
  11. Steam Deck Right Trigger Replacement, Remove the trigger bracket screws: passo 11, imagem 1 %32
    • Use a Phillips driver to remove the three 5.2 mm screws securing the right trigger bracket.
  12. Steam Deck Right Trigger Replacement, Remove the trigger bracket: passo 12, imagem 1 %32
    • Remove the right trigger bracket.
    • Replacement triggers require calibration to work as expected. To calibrate new triggers, follow this calibration guide.
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Steam Deck answers community for help.
7 outras pessoas executaram este guia.
Carsten Frauenheim
Membro desde: 03/10/20
138.524 Reputação
Autoria de 379 guias
Equipe
iFixit Membro de iFixit
Staff
121 Membros
Autoria de 19.823 guias
5Comentários do guia
This would be useful if you could actually find replacement triggers at all. I live in the UK, and cannot source these at all. I even contacted Valve about it and they cannot help me :(
Fil Sapia - Responder
I bought my replacement from this website.
Bo Seller -
The shield doesn't need to be removed for this repair. The trigger is difficult to replace. Start with the outer peg first, leftside, and then position the right-side above the peg. Apply pressure to get it over the leg, then continue pressure to get it on the peg. A little tricky, and don't forget to attach the spring first.
Bo Seller - Responder
My transistor on the left daughterboard is missing. I would like to buy a new transistor and solder it myself. Could you please provide me with the specifications of the transistor or give me a link to purchase one? The L2 button is not working because of it. It has the code "303" on it, you can see it in the images above
Kristiyan Petrov - Responder
PSA: Bo Seller is right that you do not have to remove the shield. The only purpose of steps 5–8 is to enable you to disconnect the battery, which is not essential. I skipped steps 5–8 and did not have any trouble with the repair.
David H - Responder
Comentar
Visualizações:
Últimas 24 horas: 25
Últimos 7 dias: 132
Últimos 30 dias: 671
Ao todo: 28,467
