Introdução
Use this guide to replace the right touchpad on your Steam Deck OLED. The touchpad itself is part of a larger module, including haptics, and needs to be replaced as one unit.
Although the procedure is similar, follow this guide to replace the left touchpad.
Remember to follow general electrostatic discharge (ESD) safety procedures while repairing your device.
These steps only describe how to physically remove and replace your console’s touchpad. You may need additional software tools and calibration procedures to get the replacement touchpad to function as intended.
O que você precisa
Power down your Steam Deck and unplug any cables.
Ferramenta utilizada nesse passo:FixMat$36.95
Use a T6 Torx driver to remove the eight 5.8 mm‑long screws securing the back cover.
Insert an opening pick at an upward angle between the back cover and the front shell near one of the triggers.
Slide your pick along the edge of the handle to release the clips securing it to the front shell.
Reinsert your pick and slide it along the top and bottom edges until the back cover feels loose.
Grip the unclipped handle and pull it away from the front shell to release the remaining clips.
Remove the back cover.
Grip the battery cable pull tab, located to the left of the battery.
Firmly pull the battery cable straight away from the motherboard shield (toward the battery) to disconnect it.
During disassembly, skip the next three steps.
Reinstall the two 3.8 mm‑long screws to secure the motherboard shield.
Reconnect the interconnect cable ZIF connector.
Use the flat end of a spudger to slide the battery connector into its socket on the motherboard.
Use your T6 Torx driver to remove the two 3.8 mm‑long screws securing the motherboard shield.
Lift the top edge of the motherboard shield up and flip it over the bottom edge of the frame, away from the motherboard.
Ferramenta utilizada nesse passo:Tweezers$4.99
Use the point of a spudger to flip up the small locking flap on the right thumbstick ZIF connector.
Use tweezers or your fingers to grip the cable's pull tab and slide the connector straight out of its socket to disconnect it.
Flip up the small black locking flap on the right thumbstick cable ZIF connector.
Slide the connector straight out of its socket to disconnect it.
Flip up the small locking flap on the button board cable ZIF connector, located in the bottom left corner.
Repeat the ZIF cable disconnection procedure for the remaining three ZIF connectors:
The touchpad cable
The touchpad board cable
The action buttons and menu button cable
Insert the point of your spudger under the neck of the haptics cable connector.
Gently pry up to disconnect it.
Use your T6 Torx driver to remove the four screws securing the right button board:
Two 5.9 mm‑long screws
One 3.8 mm‑long screw
One 4.9 mm‑long screw
Insert the point of your spudger between the bottom left corner of the button board and the frame.
Pry up until you can grab the button board with your fingers.
Remove the button board.
Use your T6 Torx driver to remove the three 5.9 mm‑long screws securing the right thumbstick.
Grip the edges of the thumbstick board and rotate it clockwise to clear the trigger.
Remove the thumbstick.
Flip up the small locking flap on the right touchpad board ZIF connector.
Lift the connector until its arms are free of the socket and slide it straight out to disconnect it.
Use your T6 Torx driver to remove the four 5 mm‑long screws securing the touchpad board.
Use your T6 Torx driver to remove the four 6 mm‑long screws securing the touchpad.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Steam Deck OLED answers community for help.
Um comentário
Where can the touchpads be bought from? Can't find them anywhere...
