Ir para o conteúdo principal
Steam Deck OLED Back Cover Replacement
O que você precisa
  1. Steam Deck OLED Back Cover Replacement, Prepare your Steam Deck for disassembly: passo 1, imagem 1 %32 Steam Deck OLED Back Cover Replacement, Prepare your Steam Deck for disassembly: passo 1, imagem 2 %32 Steam Deck OLED Back Cover Replacement, Prepare your Steam Deck for disassembly: passo 1, imagem 3 %32
    • Turn on your Steam Deck and allow the battery to discharge below 25% before starting your repairs, as a charged lithium-ion polymer battery can be dangerous if accidentally punctured.
    • As an extra precaution, Valve recommends putting your Steam Deck into battery storage mode within the BIOS before starting any internal repairs. Read how to do that here.
    • Power down your Steam Deck and unplug any cables.
    • If you have a microSD card installed, make sure to remove it before opening the Steam Deck. If you attempt to remove the back cover with it still installed, it could snap right in half.
    • During your repair, it can be helpful at times to lay the Steam Deck face-down in its case to protect the thumbsticks and prevent wobble.
  2. Steam Deck OLED Back Cover Replacement, Remove the back cover screws: passo 2, imagem 1 %32 Steam Deck OLED Back Cover Replacement, Remove the back cover screws: passo 2, imagem 2 %32
    Ferramenta utilizada nesse passo:
    FixMat
    $36.95
    Comprar
    • Use a T6 Torx driver to remove the eight 5.8 mm‑long screws securing the back cover.
  3. Steam Deck OLED Back Cover Replacement, Unclip a handle: passo 3, imagem 1 %32 Steam Deck OLED Back Cover Replacement, Unclip a handle: passo 3, imagem 2 %32 Steam Deck OLED Back Cover Replacement, Unclip a handle: passo 3, imagem 3 %32
    • Insert an opening pick at an upward angle between the back cover and the front shell near one of the triggers.
    • If you can't insert your pick here, try along the top or bottom edges of the Steam Deck OLED before sliding it toward the handle.
    • Slide your pick along the edge of the handle to release the clips securing it to the front shell.
  4. Steam Deck OLED Back Cover Replacement, Unclip the top and bottom edges: passo 4, imagem 1 %32 Steam Deck OLED Back Cover Replacement, Unclip the top and bottom edges: passo 4, imagem 2 %32 Steam Deck OLED Back Cover Replacement, Unclip the top and bottom edges: passo 4, imagem 3 %32
    • Reinsert your pick and slide it along the top and bottom edges until the back cover feels loose.
  5. Steam Deck OLED Back Cover Replacement, Remove the back cover: passo 5, imagem 1 %32 Steam Deck OLED Back Cover Replacement, Remove the back cover: passo 5, imagem 2 %32 Steam Deck OLED Back Cover Replacement, Remove the back cover: passo 5, imagem 3 %32
    • Grip the unclipped handle and pull it away from the front shell to release the remaining clips.
    • Remove the back cover.
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Steam Deck OLED answers community for help.
Uma outra pessoa concluiu este guia.
Clay Eickemeyer
Membro desde: 09/19/22
67.256 Reputação
Autoria de 453 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 136
Autoria de 17.420 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 9
Últimos 7 dias: 86
Últimos 30 dias: 406
Duração total: 2,342
