Ir para o conteúdo principal
Steam Controller (2nd Gen, 2026) Main Board Replacement
O que você precisa
  1. Steam Controller (2nd Gen, 2026) Main Board Replacement, Before you begin: passo 1, imagem 1 %32 Steam Controller (2nd Gen, 2026) Main Board Replacement, Before you begin: passo 1, imagem 2 %32 Steam Controller (2nd Gen, 2026) Main Board Replacement, Before you begin: passo 1, imagem 3 %32
    • Let your controller's battery drain below 25% before starting this repair.
    • Unplug all cables and accessories from the controller, including the Steam Controller Puck.
    • During your repair, it can be helpful to lay the Steam Controller on a clean, soft cloth for stabilization and to prevent scratches.
    Pergunte ao FixBot
    Comentar
  2. Steam Controller (2nd Gen, 2026) Main Board Replacement, Remove the back cover screws: passo 2, imagem 1 %32 Steam Controller (2nd Gen, 2026) Main Board Replacement, Remove the back cover screws: passo 2, imagem 2 %32
    Ferramenta utilizada neste passo:
    TR6 Torx Security Screwdriver
    $5.99
    Pergunte ao FixBot
    Comentar
  3. Steam Controller (2nd Gen, 2026) Main Board Replacement, Remove the back cover: passo 3, imagem 1 %32 Steam Controller (2nd Gen, 2026) Main Board Replacement, Remove the back cover: passo 3, imagem 2 %32
    • Remove the back cover.
    Pergunte ao FixBot
    Comentar
  4. Steam Controller (2nd Gen, 2026) Main Board Replacement, Remove the battery: passo 4, imagem 1 %32 Steam Controller (2nd Gen, 2026) Main Board Replacement, Remove the battery: passo 4, imagem 2 %32 Steam Controller (2nd Gen, 2026) Main Board Replacement, Remove the battery: passo 4, imagem 3 %32
    • If your battery is swollen, take appropriate precautions. Never reinstall a swollen battery—replace it with a new one.
    • Lift the right edge of the battery to remove it.
    • During reassembly, first slide the left side of the battery into place so its connector is fully seated. Then, press the right side into place to secure it.
    Pergunte ao FixBot
    Comentar
  5. Steam Controller (2nd Gen, 2026) Main Board Replacement, Remove the mounting bracket screws: passo 5, imagem 1 %32 Steam Controller (2nd Gen, 2026) Main Board Replacement, Remove the mounting bracket screws: passo 5, imagem 2 %32
    • During the rest of your repair, don't forcefully push the controller down onto your work surface—you may damage the thumbsticks and trackpads.
    • Use a T6 Torx screwdriver to remove the four 7.4 mm‑long screws securing the battery mounting bracket.
    Pergunte ao FixBot
    Comentar
  6. Steam Controller (2nd Gen, 2026) Main Board Replacement, Remove the mounting bracket: passo 6, imagem 1 %32 Steam Controller (2nd Gen, 2026) Main Board Replacement, Remove the mounting bracket: passo 6, imagem 2 %32
    Pergunte ao FixBot
    Comentar
  7. Steam Controller (2nd Gen, 2026) Main Board Replacement, Disconnect the rumble motors: passo 7, imagem 1 %32 Steam Controller (2nd Gen, 2026) Main Board Replacement, Disconnect the rumble motors: passo 7, imagem 2 %32 Steam Controller (2nd Gen, 2026) Main Board Replacement, Disconnect the rumble motors: passo 7, imagem 3 %32
    • Don't pull on the rumble motor's delicate wires—they're easily damaged. Be careful not to pinch the wires with your tweezers, and only pull on the connector itself.
    • Firmly grip the short edges of one rumble motor connector with a pair of tweezers and pull straight up to disconnect it
    • Grip the tweezers as close to the tip as possible to get a better hold on the connector.
    Pergunte ao FixBot
    Comentar
  8. Steam Controller (2nd Gen, 2026) Main Board Replacement: passo 8, imagem 1 %32 Steam Controller (2nd Gen, 2026) Main Board Replacement: passo 8, imagem 2 %32 Steam Controller (2nd Gen, 2026) Main Board Replacement: passo 8, imagem 3 %32
    • Repeat to disconnect the other rumble motor.
    Pergunte ao FixBot
    Comentar
  9. Steam Controller (2nd Gen, 2026) Main Board Replacement, Disconnect the interconnect cable: passo 9, imagem 1 %32 Steam Controller (2nd Gen, 2026) Main Board Replacement, Disconnect the interconnect cable: passo 9, imagem 2 %32 Steam Controller (2nd Gen, 2026) Main Board Replacement, Disconnect the interconnect cable: passo 9, imagem 3 %32
    • Be careful not to damage any of the small, surface-mounted components on the main board.
    • Use a spudger to lift the hinged locking flap on the interconnect cable ZIF connector, located on the bottom edge of the main board.
    Pergunte ao FixBot
    Comentar
  10. Steam Controller (2nd Gen, 2026) Main Board Replacement: passo 10, imagem 1 %32 Steam Controller (2nd Gen, 2026) Main Board Replacement: passo 10, imagem 2 %32
    • Use tweezers to grip the cable by its plastic pull tab and slide it out of the socket.
    Pergunte ao FixBot
    Comentar
  11. Steam Controller (2nd Gen, 2026) Main Board Replacement, Remove the main board screws: passo 11, imagem 1 %32 Steam Controller (2nd Gen, 2026) Main Board Replacement, Remove the main board screws: passo 11, imagem 2 %32 Steam Controller (2nd Gen, 2026) Main Board Replacement, Remove the main board screws: passo 11, imagem 3 %32
    • Use a T6 Torx screwdriver to remove the three 7.4 mm‑long screws securing the main board.
    • When reinstalling the screws, raise the controller so the thumbsticks aren't pressed against your work surface—pressure on the thumbsticks can cause improper alignment and seating.
    Pergunte ao FixBot
    Comentar
  12. Steam Controller (2nd Gen, 2026) Main Board Replacement, Remove the main board: passo 12, imagem 1 %32 Steam Controller (2nd Gen, 2026) Main Board Replacement, Remove the main board: passo 12, imagem 2 %32 Steam Controller (2nd Gen, 2026) Main Board Replacement, Remove the main board: passo 12, imagem 3 %32
    • Pull the main board down so the top corners clear the triggers.
    • You should be able to remove the board without removing the triggers. If you're having trouble, check out this guide to remove them.
    • Remove the main board, guiding the thumbsticks through their cutouts.
    • During reassembly, make sure the two rumble motor wires don't get trapped underneath the board. Use the four alignment posts to ensure the board is properly positioned.
    Pergunte ao FixBot
    Comentar
  13. Steam Controller (2nd Gen, 2026) Main Board Replacement, Rubber piece information: passo 13, imagem 1 %32 Steam Controller (2nd Gen, 2026) Main Board Replacement, Rubber piece information: passo 13, imagem 2 %32 Steam Controller (2nd Gen, 2026) Main Board Replacement, Rubber piece information: passo 13, imagem 3 %32
    • The rubber piece above the status LED may have been dislodged when removing the main board.
    • If the rubber piece is out of place, remove it and set it aside.
    • During reassembly, place the rubber piece so the two tabs are on the bottom and towards the back.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Spencer Day
Membro desde: 09/14/22
195.462 Reputação
Autoria de 1.243 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 20
Últimos 7 dias: 140
Últimos 30 dias: 895
Ao todo: 3,258
