Introdução
If your pencil sharpener is not turning on when you insert a pencil, you may have a faulty sensor wire. See our troubleshooting guide for more information on this problem. If the problem is your sensor wire, then follow these steps to replace the it. This guide may require some soldering to complete. For more tips and information on soldering see iFixit's soldering guide.
O que você precisa
Orient the top panel so the sensor wire's electrical connection is visible.
Using a soldering iron, de-solder the sensor wire from the sensor bracket. Be careful to avoid melting the plastic components while soldering.
Uma outra pessoa concluiu este guia.
Um comentário
The yellow wire shown in the above should be tested for continuity before unsoldering. If it’s ok, try the following:
1. Check if there is continuity across the AC power prongs using an ohmmeter. If not, the transformer is bad. That was my problem.
2. Check that the pencil actuated switch closes properly when the pencil is inserted, using an ohmmeter. Clean the contacts if necessary.
3. Check that the small shaving tray safety switch closes when the tray is inserted. It’s actuated by a tab on the R rear of the tray.
4. Apply 12V (AC or DC) to the two yellow wires. If the motor runs, the diodes and motor are ok.
5. Apply 12 VDC to the motor directly, using the two terminals that the black capacitor is attached to. Make sure to attach the negative side as marked on the capacitor, or you might blow the diodes. Use a power source that can supply at least one amp.
I will gladly donate my unit with working motor and good gearbox to anyone that asks. Add a w in front of wayde@hotmail.com
