Ir para o conteúdo principal
Staples 34462 Electric Pencil Sharpener A/C Motor Replacement
O que você precisa
  1. Staples 34462 Electric Pencil Sharpener A/C Motor Replacement, Cover: passo 1, imagem 1 %32
    • Pull out the shavings tray from the pencil sharpener.
    • Beware of loose pencil shavings falling on your workspace.
  2. Staples 34462 Electric Pencil Sharpener A/C Motor Replacement: passo 2, imagem 1 %32
    • Turn the pencil sharpener on its side.
  3. Staples 34462 Electric Pencil Sharpener A/C Motor Replacement: passo 3, imagem 1 %32
    • Using a Phillips00 screwdriver, remove the two front 11.6mm screws.
    • Using the plastic opening tool, remove the back plastic feet.
    • After removing the back plastic feet, using a Phillips 00 screwdriver, remove the two back 11.6mm screws.
    • The hole is deeper than you may think. It may take some time to get the screwdriver to click in.
  4. Staples 34462 Electric Pencil Sharpener A/C Motor Replacement: passo 4, imagem 1 %32
    • Carefully pull apart the bottom panel from the top panel.
    • Be careful not to pull too forcefully as the panels are connected by wires.
    • Beware of pencil shavings falling out onto your workspace.
  5. Staples 34462 Electric Pencil Sharpener A/C Motor Replacement: passo 5, imagem 1 %32
    • Using a Phillips00 screwdriver, remove two 8.9mm flat edge screws from the top section of the top panel.
  6. Staples 34462 Electric Pencil Sharpener A/C Motor Replacement: passo 6, imagem 1 %32
    • Using a Phillips00 screwdriver, remove two 10.3mm screws from the middle section of the top panel.
  7. Staples 34462 Electric Pencil Sharpener A/C Motor Replacement: passo 7, imagem 1 %32
    • Carefully pull the cover from the top panel and set it aside.
  8. Staples 34462 Electric Pencil Sharpener A/C Motor Replacement, A/C Motor: passo 8, imagem 1 %32
    • Using a Philips 00 screwdriver, remove the six 9.87mm screws securing the gear housing.
  9. Staples 34462 Electric Pencil Sharpener A/C Motor Replacement: passo 9, imagem 1 %32
    • Carefully pull apart the gear housing's panels.
    • The gears are lubricated by petroleum jelly.
  10. Staples 34462 Electric Pencil Sharpener A/C Motor Replacement: passo 10, imagem 1 %32
    • Using a Philips 00 screwdriver, remove the first 10.3mm screw attaching the A/C motor to the panel.
  11. Staples 34462 Electric Pencil Sharpener A/C Motor Replacement: passo 11, imagem 1 %32
    • Gently pry the gear from the panel with a spudger to expose the second screw holding the electric A/C motor to the panel.
    • To ease reassembly, note the orientation of the gear as you pry it free.
  12. Staples 34462 Electric Pencil Sharpener A/C Motor Replacement: passo 12, imagem 1 %32
    • Using a Philips 00 screwdriver, remove the second 10.3mm screw securing the electric A/C motor to the panel.
  13. Staples 34462 Electric Pencil Sharpener A/C Motor Replacement: passo 13, imagem 1 %32
    • Pull out the electric A/C motor from the gear housing panel.
  14. Staples 34462 Electric Pencil Sharpener A/C Motor Replacement: passo 14, imagem 1 %32
    • Using a soldering iron, carefully de-solder the two wires from the electric A/C motor.
    • This step requires soldering. See iFixit's soldering guide for more tips and information.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 15
Duração total: 1,957
