Ir para o conteúdo principal
Spy Net Ultra Vision Goggles Microphone Replacement
O que você precisa
  1. Spy Net Ultra Vision Goggles Microphone Replacement, Open the Device: passo 1, imagem 1 %32
    • Using the screwdriver, remove the six silver 11.4 mm Phillips #0 screws that hold the device shell in place.
    • Pull apart the back of the device, using the plastic opening tool if needed. To do this, locate the groves running along the side of the entire device and wedge it open.
  2. Spy Net Ultra Vision Goggles Microphone Replacement, Un-Solder the Wiring from the Circuit Board: passo 2, imagem 1 %32
    • Find the connection of the red and black wires to the circuit board behind the LED screen.
    • Un-solder the wires from the board using the soldering iron.
    • Need Help Soldering? Check out Como soldar e dessoldar contatos
  3. Spy Net Ultra Vision Goggles Microphone Replacement, Un-Solder the Microphone: passo 3, imagem 1 %32
    • Find the connection of the red and black wires to the funnel-shaped lens cover.
    • Un-solder the wires from the microphone using the soldering iron.
    • Remove the red and black wires from the device and solder on the replacement.
Conclusão
Justin Diehl
Membro desde: 09/22/14
66 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 4-5, Brown Fall 2014 Membro de USF Tampa, Team 4-5, Brown Fall 2014
USFT-BROWN-F14S4G5
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 14
Últimos 30 dias: 14
Duração total: 341
