Ir para o conteúdo principal
Sony a7 AV Port Replacement
O que você precisa
  1. Sony a7 AV Port Replacement, Rear Disassembly: passo 1, imagem 1 %32
    • Remove the eyepiece cover by removing the four M1.5x4mm screws with a PH00 Phillips screwdriver.
    • Remove the M1.5x4mm screw that retains the adjustment wheel with a PH00 Phillips screwdriver.
  2. Sony a7 AV Port Replacement: passo 2, imagem 1 %32 Sony a7 AV Port Replacement: passo 2, imagem 2 %32 Sony a7 AV Port Replacement: passo 2, imagem 3 %32
    • Remove the six M1.5x4mm screws with a PH00 Phillips screwdriver.
  3. Sony a7 AV Port Replacement: passo 3, imagem 1 %32
    • Remove one M1.5x4mm screw with a PH00 Phillips screwdriver.
  4. Sony a7 AV Port Replacement: passo 4, imagem 1 %32 Sony a7 AV Port Replacement: passo 4, imagem 2 %32
    • Remove the four M 1.5x2mm screws.
  5. Sony a7 AV Port Replacement: passo 5, imagem 1 %32 Sony a7 AV Port Replacement: passo 5, imagem 2 %32 Sony a7 AV Port Replacement: passo 5, imagem 3 %32
    • Once the screws have been removed, unsnap and lift the rear plastic cover off of the camera.
  6. Sony a7 AV Port Replacement: passo 6, imagem 1 %32
    • Using the blunt tweezers, remove the blue ribbon cable.
    • For additional guidance and tips on how to properly attach and detach connector cables, please reference iFixit's guide to connector cables here.
  7. Sony a7 AV Port Replacement: passo 7, imagem 1 %32 Sony a7 AV Port Replacement: passo 7, imagem 2 %32
    • Place the tweezers on the side of the circuit board and lift it from underneath so as to free it from the three retaining tabs.
  8. Sony a7 AV Port Replacement: passo 8, imagem 1 %32 Sony a7 AV Port Replacement: passo 8, imagem 2 %32 Sony a7 AV Port Replacement: passo 8, imagem 3 %32
    • Remove four M1.5x4mm screws using a PH00 Phillips screwdriver.
  9. Sony a7 AV Port Replacement: passo 9, imagem 1 %32
    • Lift the metal plate and LCD screen away from the camera body.
  10. Sony a7 AV Port Replacement: passo 10, imagem 1 %32
    • Detach the amber ribbon cable from the motherboard.
  11. Sony a7 AV Port Replacement, Motherboard: passo 11, imagem 1 %32 Sony a7 AV Port Replacement, Motherboard: passo 11, imagem 2 %32
    • Peel off the small adhesive tape located on the top right side of the motherboard.
  12. Sony a7 AV Port Replacement: passo 12, imagem 1 %32 Sony a7 AV Port Replacement: passo 12, imagem 2 %32
    • Remove the exposed ribbon cable by using the iFixit opening tools
  13. Sony a7 AV Port Replacement: passo 13, imagem 1 %32
    • Peel off the large black protective adhesive from the motherboard.
  14. Sony a7 AV Port Replacement: passo 14, imagem 1 %32 Sony a7 AV Port Replacement: passo 14, imagem 2 %32
    • Remove the four visible ribbon cables by using the spudger.
    • Removing the ribbon cables will require lifting a lever located on the connecter in order to pull out the cable.
  15. Sony a7 AV Port Replacement: passo 15, imagem 1 %32 Sony a7 AV Port Replacement: passo 15, imagem 2 %32 Sony a7 AV Port Replacement: passo 15, imagem 3 %32
    • Remove the one U.FL plug by using the spudger.
    • Using the spudger, remove the four remaining ribbon cables.
    • These ribbon cables do not have the requirement to lift a lever on the connector as specified in previous steps.
  16. Sony a7 AV Port Replacement: passo 16, imagem 1 %32
    • Remove one M1.5x2mm screw with a PH00 Phillips screwdriver.
    • Remove one coarse threaded 5mm screw with a PH00 Phillips screwdriver.
  17. Sony a7 AV Port Replacement: passo 17, imagem 1 %32 Sony a7 AV Port Replacement: passo 17, imagem 2 %32 Sony a7 AV Port Replacement: passo 17, imagem 3 %32
    • Lift the motherboard from the camera body.
    • It helps to pick up the right side of the board first, and then work sequentially down the board. Be sure to gently ease the motherboard from its clips down the remainder of the side.
    • Exercise extreme caution when removing the motherboard as it can be fragile, and damage to it could mean the camera will become unrecoverable.
  18. Sony a7 AV Port Replacement: passo 18, imagem 1 %32
    • Remove the two visible ribbon cables by using the forceps.
  19. Sony a7 AV Port Replacement, AV Port: passo 19, imagem 1 %32 Sony a7 AV Port Replacement, AV Port: passo 19, imagem 2 %32
    • Take a soldering iron and place it onto a leg of the failed AV port.
    • Use a small flat head screwdriver to pry up each leg while the solder is molten.
    • The soldering iron and solder will be hot, exercise extreme caution when handling.
    • Always wear eye protection when soldering connections, solder can splatter and cause burns.
    • Do not inhale any smoke or fumes that may be given off during the soldering process, as they can be toxic.
    • For help and tips on how to effectively solder like a professional, please reference the iFixit guide on soldering here.
  20. Sony a7 AV Port Replacement: passo 20, imagem 1 %32
    • Repeat the actions in the previous step to the remaining three legs of the faulty AV port until the connector is able to be moved, and is free.
    • All of the tips and cautions about the soldering process still apply in this step, continue to exercise extreme due diligence and caution.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 31
Duração total: 1,554
