Ir para o conteúdo principal
Sony Xperia Z1s Screen Replacement
O que você precisa
  1. Sony Xperia Z1s Screen Replacement, Battery: passo 1, imagem 1 %32
    • Insert the opening pick in the crease between the rear cover and the body of the phone.
    • Pry along the edge to lift and remove the back cover.
    Pergunte ao FixBot
    Comentar
  2. Sony Xperia Z1s Screen Replacement: passo 2, imagem 1 %32
    • Using the T4 Torx screwdriver, remove five 5 mm screws from the panel above the battery.
    • Remove the panel by grabbing its bottom edge and lifting upwards.
    Pergunte ao FixBot
    Comentar
  3. Sony Xperia Z1s Screen Replacement: passo 3, imagem 1 %32
    • Use the opening pick to pry off the battery flex cable.
    Pergunte ao FixBot
    Comentar
  4. Sony Xperia Z1s Screen Replacement: passo 4, imagem 1 %32
    • Using the T4 Torx screwdriver, remove two 5 mm screws from the bottom corners of the battery.
    Pergunte ao FixBot
    Comentar
  5. Sony Xperia Z1s Screen Replacement: passo 5, imagem 1 %32
    • Firmly press the suction cup onto the battery.
    • Pull the battery out using the suction handle.
    Pergunte ao FixBot
    Comentar
  6. Sony Xperia Z1s Screen Replacement, Motherboard: passo 6, imagem 1 %32
    • Use the opening pick to pry off the camera flex cable.
    • Continue to lift the flex cable upward until the camera pops out.
    Pergunte ao FixBot
    Comentar
  7. Sony Xperia Z1s Screen Replacement: passo 7, imagem 1 %32
    • Use the opening pick to pry off the three flex cables on the bottom of the motherboard.
    • Do the same for the one flex cable at the top of the motherboard.
    Pergunte ao FixBot
    Comentar
  8. Sony Xperia Z1s Screen Replacement: passo 8, imagem 1 %32
    • Use the opening pick to pry off the black plastic cover above the top of the motherboard.
    Pergunte ao FixBot
    Comentar
  9. Sony Xperia Z1s Screen Replacement: passo 9, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Use a pair of tweezers to lift up the motherboard.
    • If you are having trouble removing the motherboard, try lifting up the left edge first and sliding the rest of the motherboard out.
    Pergunte ao FixBot
    Comentar
  10. Sony Xperia Z1s Screen Replacement: passo 10, imagem 1 %32
    • Use a pair of tweezers to remove the pin connection on the motherboard.
    • Fully remove the motherboard from the device.
    Pergunte ao FixBot
    Comentar
  11. Sony Xperia Z1s Screen Replacement, LCD Screen: passo 11, imagem 1 %32
    • Using the T4 Torx screwdriver, unscrew the single 5 mm screw from the bottom left corner of the loudspeaker cover.
    Pergunte ao FixBot
    Comentar
  12. Sony Xperia Z1s Screen Replacement: passo 12, imagem 1 %32
    • Slide the opening pick under the edge of the loudspeaker cover.
    • Gently lift and pry up the loudspeaker cover.
    Pergunte ao FixBot
    Comentar
  13. Sony Xperia Z1s Screen Replacement: passo 13, imagem 1 %32
    • Use your fingers to slowly peel back the black flex cable in the middle of the phone until it is only connected at the bottom of the phone.
    Pergunte ao FixBot
    Comentar
  14. Sony Xperia Z1s Screen Replacement: passo 14, imagem 1 %32
    • Gently slide the opening pick underneath the screen.
    • Lift the opening pick upward to remove the screen.
    • If needed, use a heat gun to loosen the adhesive holding the screen by aiming it around the edge of the screen.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Emily Scruggs
Membro desde: 09/28/21
127 Reputação
Autoria de 1 guia
Equipe
Clemson, Team 4-4, Hunter Fall 2021 Membro de Clemson, Team 4-4, Hunter Fall 2021
CLEM-HUNTER-F21S4G4
5 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 24
Ao todo: 583
