Ir para o conteúdo principal
Sony WH-CH710N Battery Replacement
O que você precisa
  1. Sony WH-CH710N Battery Replacement, Right Ear Cup: passo 1, imagem 1 %32
    • Pinch the right ear pad cushion and gently pull it away from the ear cup to remove it.
    Pergunte ao FixBot
    Comentar
  2. Sony WH-CH710N Battery Replacement: passo 2, imagem 1 %32
    • Use a Phillips #1 screwdriver to remove the four 4.0 mm screws from the outer ear plate.
    Pergunte ao FixBot
    Comentar
  3. Sony WH-CH710N Battery Replacement: passo 3, imagem 1 %32 Sony WH-CH710N Battery Replacement: passo 3, imagem 2 %32 Sony WH-CH710N Battery Replacement: passo 3, imagem 3 %32
    • Using even pressure around all edges, gently pull the black outer ear plate away from the cup of the earphone.
    • The plastic is fragile, so it is important not to force the removal. It may be helpful to use the opening tool or spudger to pry around the edge of the outer ear plate.
    Pergunte ao FixBot
    Comentar
  4. Sony WH-CH710N Battery Replacement: passo 4, imagem 1 %32 Sony WH-CH710N Battery Replacement: passo 4, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the four 3.0 mm screws from the inner ear plate.
    Pergunte ao FixBot
    Comentar
  5. Sony WH-CH710N Battery Replacement: passo 5, imagem 1 %32 Sony WH-CH710N Battery Replacement: passo 5, imagem 2 %32
    • Gently grasp the black inner ear plate and pull it away from the cup of the earphone, exposing the internal components.
    • The internal components are still attached to the wires, which are glued into the inner ear plate. Be extremely careful not to pull on the wires while performing this step.
    Pergunte ao FixBot
    Comentar
  6. Sony WH-CH710N Battery Replacement, Battery: passo 6, imagem 1 %32
    • Push on alternating sides of the JST connector, to release it.
    • If that doesn't work, use a pair of tweezers to firmly grip the sides of the battery connector and pull straight away from the socket. Hold the tweezers closer to the connector to get a better grip.
    Pergunte ao FixBot
    Comentar
  7. Sony WH-CH710N Battery Replacement: passo 7, imagem 1 %32 Sony WH-CH710N Battery Replacement: passo 7, imagem 2 %32 Sony WH-CH710N Battery Replacement: passo 7, imagem 3 %32
    • Insert some isopropyl alcohol or adhesive remover underneath the battery to soften the adhesive.
    • Gently slide a plastic opening pick around the edges of the battery to loosen the adhesive before you remove it.
    • Use a suction cup to lift the battery out.
    • Don't pry the battery as this can cause an explosion or fire.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 26
Ao todo: 106
