Ir para o conteúdo principal
Sony Vaio VGN-FS640 RAM Replacement
O que você precisa
  1. Sony Vaio VGN-FS640 RAM Replacement, Battery: passo 1, imagem 1 %32
    • Lay the closed laptop on its screen so the bottom is facing towards you.
    Pergunte ao FixBot
    Comentar
  2. Sony Vaio VGN-FS640 RAM Replacement: passo 2, imagem 1 %32
    • Push both latches towards the center of the battery.
    Pergunte ao FixBot
    Comentar
  3. Sony Vaio VGN-FS640 RAM Replacement: passo 3, imagem 1 %32 Sony Vaio VGN-FS640 RAM Replacement: passo 3, imagem 2 %32
    • Revome the battery by pushing it away from the laptop.
    • Set the battery away from the laptop.
    Pergunte ao FixBot
    Comentar
  4. Sony Vaio VGN-FS640 RAM Replacement, RAM Cover: passo 4, imagem 1 %32 Sony Vaio VGN-FS640 RAM Replacement, RAM Cover: passo 4, imagem 2 %32
    • With the bottom of the laptop facing up, locate the RAM cover.
    • The RAM is covered by the panel with four columns of vents.
    • Locate the screw (Length: 4.8 mm) holding down the panel, which is near the edge of the laptop. Unscrew it with your phillips #0 screwdriver.
    Pergunte ao FixBot
    Comentar
  5. Sony Vaio VGN-FS640 RAM Replacement: passo 5, imagem 1 %32 Sony Vaio VGN-FS640 RAM Replacement: passo 5, imagem 2 %32 Sony Vaio VGN-FS640 RAM Replacement: passo 5, imagem 3 %32
    • Use your fingers to slide the cover away from the laptop. (It will only slide a few millimeters)
    • Once the panel is out of its locked position, it can be lifted out without any resistance.
    Pergunte ao FixBot
    Comentar
  6. Sony Vaio VGN-FS640 RAM Replacement, RAM: passo 6, imagem 1 %32 Sony Vaio VGN-FS640 RAM Replacement, RAM: passo 6, imagem 2 %32 Sony Vaio VGN-FS640 RAM Replacement, RAM: passo 6, imagem 3 %32
    • To remove the RAM, use sharp end of a spudger to push the two silver tabs (see picture) away from the green RAM chip.
    • When both silver tabs are moved to the side, one edge of the RAM chip will pop up from its original position.
    • Use your fingers to grab the raised edge of the RAM and pull the chip away from its connection to the laptop.
    Pergunte ao FixBot
    Comentar
  7. Sony Vaio VGN-FS640 RAM Replacement: passo 7, imagem 1 %32
    • To install the new RAM, grip the new chip exactly the same way as you gripped the old chip when you removed it.
    • Insert the gold leads of the RAM into the connection at the same angle the original chip was raised at after the tabs were released.
    • There is a raised tab on the connection that mates with a slit in the RAM to ensure you do not put the chip in upside down.
    Pergunte ao FixBot
    Comentar
  8. Sony Vaio VGN-FS640 RAM Replacement: passo 8, imagem 1 %32
    Pergunte ao FixBot
    Comentar
Linha de Chegada
Equipe
Cal Poly, Team 24-32, Regan Spring 2010 Membro de Cal Poly, Team 24-32, Regan Spring 2010
CPSU-REGAN-S10S24G32
4 Membros
Autoria de 16 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 29
Ao todo: 10,947
