Ir para o conteúdo principal
Sony Vaio VGN-FS640 RAM Cover Replacement
O que você precisa
    1. Sony Vaio VGN-FS640 RAM Cover Replacement, Battery: passo 1, imagem 1 %32
      • Lay the closed laptop on its screen so the bottom is facing towards you.
      Pergunte ao FixBot
      Comentar
    2. Sony Vaio VGN-FS640 RAM Cover Replacement: passo 2, imagem 1 %32
      • Push both latches towards the center of the battery.
      Pergunte ao FixBot
      Comentar
    3. Sony Vaio VGN-FS640 RAM Cover Replacement: passo 3, imagem 1 %32 Sony Vaio VGN-FS640 RAM Cover Replacement: passo 3, imagem 2 %32
      • Revome the battery by pushing it away from the laptop.
      • Set the battery away from the laptop.
      Pergunte ao FixBot
      Comentar
    1. Sony Vaio VGN-FS640 RAM Cover Replacement, RAM Cover: passo 4, imagem 1 %32 Sony Vaio VGN-FS640 RAM Cover Replacement, RAM Cover: passo 4, imagem 2 %32
      • With the bottom of the laptop facing up, locate the RAM cover.
      • The RAM is covered by the panel with four columns of vents.
      • Locate the screw (Length: 4.8 mm) holding down the panel, which is near the edge of the laptop. Unscrew it with your phillips #0 screwdriver.
      Pergunte ao FixBot
      Comentar
    2. Sony Vaio VGN-FS640 RAM Cover Replacement: passo 5, imagem 1 %32 Sony Vaio VGN-FS640 RAM Cover Replacement: passo 5, imagem 2 %32 Sony Vaio VGN-FS640 RAM Cover Replacement: passo 5, imagem 3 %32
      • Use your fingers to slide the cover away from the laptop. (It will only slide a few millimeters)
      • Once the panel is out of its locked position, it can be lifted out without any resistance.
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
Cal Poly, Team 24-32, Regan Spring 2010 Membro de Cal Poly, Team 24-32, Regan Spring 2010
CPSU-REGAN-S10S24G32
4 Membros
Autoria de 16 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 30
Ao todo: 5,284
