Ir para o conteúdo principal
Sony Vaio PCG-F420 Keyboard Replacement
O que você precisa
  1. Sony Vaio PCG-F420 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • The battery is located on the left side of the laptop, as shown by the red circle.
    • Make sure the laptop is disconnected and turned completely off.
    Pergunte ao FixBot
    Comentar
  2. Sony Vaio PCG-F420 Keyboard Replacement: passo 2, imagem 1 %32
    • Remove the battery by following these steps.
    • Pull the plastic cover down (indicated by the arrow on the cover) and then swing it upwards to reveal the battery compartment.
    • The battery can now be removed by pulling it.
    Pergunte ao FixBot
    Comentar
  3. Sony Vaio PCG-F420 Keyboard Replacement, Keyboard: passo 3, imagem 1 %32
    • Use your Philips #00 screwdriver to unscrew the small screw counterclockwise. This screw is for the audio/visual jacks on the left side of the laptop.
    Pergunte ao FixBot
    Comentar
  4. Sony Vaio PCG-F420 Keyboard Replacement: passo 4, imagem 1 %32
    • Unlock the cover between the keyboard and screen.
    • Gently slide it to the right and lift it up.
    • Exercise caution to avoid excessive force, as wires are connected.
    • Be mindful not to pull the keyboard too forcefully as it remains connected to wires, which we will address in the next step.
    Pergunte ao FixBot
    Comentar
  5. Sony Vaio PCG-F420 Keyboard Replacement: passo 5, imagem 1 %32
    • Lift up the cover and lean it against the display so it is out of the way for the rest of the process.
    • Remove the small screw above the F6 key on the keyboard. Place screw in container to ensure it wont be lost.
    Pergunte ao FixBot
    Comentar
  6. Sony Vaio PCG-F420 Keyboard Replacement: passo 6, imagem 1 %32
    • Find the green ribbon as indicated in the picture by the red circle. This is what connects the keyboard to the motherboard.
    Pergunte ao FixBot
    Comentar
  7. Sony Vaio PCG-F420 Keyboard Replacement: passo 7, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Carefully unplug the ribbon cable using a pair of tweezers.
    • Lift up the white bar near the connection to the motherboard, and lightly lift the ribbon to release it from the motherboard.
    Pergunte ao FixBot
    Comentar
  8. Sony Vaio PCG-F420 Keyboard Replacement: passo 8, imagem 1 %32 Sony Vaio PCG-F420 Keyboard Replacement: passo 8, imagem 2 %32
    • Now, pull on the ribbon cable, and it will detach from the motherboard.
    • Your keyboard is now safely detached, allowing for necessary repairs or replacements.
    Pergunte ao FixBot
    Comentar
  9. Sony Vaio PCG-F420 Keyboard Replacement: passo 9, imagem 1 %32
    • Your keyboard is now safety detached. Necessary repairs or replacements can be made from here.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Cal Poly, Team 29-77, Johann Spring 2010 Membro de Cal Poly, Team 29-77, Johann Spring 2010
CPSU-JOHANN-S10S29G77
5 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 16
Últimos 30 dias: 41
Ao todo: 2,942
