Ir para o conteúdo principal
Sony SRS-XB43 LED Module Replacement
O que você precisa
  1. Sony SRS-XB43 LED Module Replacement, Faceplate: passo 1, imagem 1 %32 Sony SRS-XB43 LED Module Replacement, Faceplate: passo 1, imagem 2 %32
    • Insert the metal spudger into the mesh's seam/opening located at the bottom of the speaker.
    • Begin applying pressure, prying along the run of the seam until the mesh cover begins to come loose.
    • Fully open the hinged mesh cover and pry it off the unit.
    Pergunte ao FixBot
    Comentar
  2. Sony SRS-XB43 LED Module Replacement: passo 2, imagem 1 %32
    • Turn the speaker so the back is facing you.
    • Remove the factory tamper seal below the speaker volume toggle to reveal a single screw.
    • Remove the single screw using a T8 Torx.
    Pergunte ao FixBot
    Comentar
  3. Sony SRS-XB43 LED Module Replacement: passo 3, imagem 1 %32
    • Remove all ten screws using a Phillips #1 screwdriver.
    Pergunte ao FixBot
    Comentar
  4. Sony SRS-XB43 LED Module Replacement: passo 4, imagem 1 %32 Sony SRS-XB43 LED Module Replacement: passo 4, imagem 2 %32
    • Slowly lift the speaker face off of the housing unit.
    • Unplug the six wires connecting the faceplate to the motherboard.
    Pergunte ao FixBot
    Comentar
  5. Sony SRS-XB43 LED Module Replacement, Battery: passo 5, imagem 1 %32 Sony SRS-XB43 LED Module Replacement, Battery: passo 5, imagem 2 %32
    • Orient the speaker's backplate so that the plastic chassis and internal electronics are facing upwards.
    • Remove the eight 10 mm screws securing the motherboard chassis to the backplate using a Phillips #1 screwdriver.
    • Grab the motherboard chassis and gently remove it from the backplate of the speaker.
    Pergunte ao FixBot
    Comentar
  6. Sony SRS-XB43 LED Module Replacement: passo 6, imagem 1 %32 Sony SRS-XB43 LED Module Replacement: passo 6, imagem 2 %32 Sony SRS-XB43 LED Module Replacement: passo 6, imagem 3 %32
    • Orient the motherboard chassis so that the side with the six buttons is facedown on the table and the opposite side is visible to you.
    • Disconnect the seven-prong cable (the one with red, yellow, and black wires) plugged into the motherboard by prying on its edge/extruding lip with a spudger.
    Pergunte ao FixBot
    Comentar
  7. Sony SRS-XB43 LED Module Replacement: passo 7, imagem 1 %32 Sony SRS-XB43 LED Module Replacement: passo 7, imagem 2 %32
    • Orient the plastic chassis so that the port housing PCB is facing upward.
    • Remove the plastic black film covering the battery, leaving the blue battery exposed.
    Pergunte ao FixBot
    Comentar
  8. Sony SRS-XB43 LED Module Replacement: passo 8, imagem 1 %32 Sony SRS-XB43 LED Module Replacement: passo 8, imagem 2 %32
    • Lightly pull the seven-prong cable upwards until the battery is angled in such a way that you can get a proper grip on both sides with your fingers.
    • Using your fingers, pull upwards until the battery is removed from its enclosure.
    • Do not use a spudger or other flat tools to pry in between the seam of the battery and the battery compartment, as it is possible to damage the battery.
    Pergunte ao FixBot
    Comentar
  9. Sony SRS-XB43 LED Module Replacement, LED Module: passo 9, imagem 1 %32
    • Orient the motherboard chassis so that the battery compartment is facing upwards.
    • Identify the two LED control PCBs located on the left and right edges of the plastic chassis.
    Pergunte ao FixBot
    Comentar
  10. Sony SRS-XB43 LED Module Replacement: passo 10, imagem 1 %32 Sony SRS-XB43 LED Module Replacement: passo 10, imagem 2 %32 Sony SRS-XB43 LED Module Replacement: passo 10, imagem 3 %32
    • Identify the black latch on each of the plugs that are connected to the PBCs.
    • Swing the black latch open by gently prying the front/extruding lip of the plug with a spudger or other flat tool.
    • To give a sense of direction, the latch should swing away from you or towards the LED (metallic square).
    • Grab each ribbon cable and apply a horizontal pulling force (with respect to the LED control PCBs) to disconnect them from the connectors.
    Pergunte ao FixBot
    Comentar
  11. Sony SRS-XB43 LED Module Replacement: passo 11, imagem 1 %32 Sony SRS-XB43 LED Module Replacement: passo 11, imagem 2 %32 Sony SRS-XB43 LED Module Replacement: passo 11, imagem 3 %32
    Ferramenta utilizada neste passo:
    Plastic Cards
    $2.99
    • Insert the spudger below the LED control PCBs and pry to remove it from the plastic chassis.
    • The PCBs are held onto the chassis with a considerably strong double-sided tape. If the spudger is too thick and can not fit under the PCBs, use a thin plastic pick or plastic card.
    Pergunte ao FixBot
    Comentar
Conclusão
Isaac Oliveira
Membro desde: 10/26/22
282 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 3-5, Botvin Fall 2022 Membro de UMass Dartmouth, Team 3-5, Botvin Fall 2022
UMASSD-BOTVIN-F22S3G5
4 Membros
Autoria de 5 guias
1Comentário do guia
i need email to contact You please
Danny Bryan Vega - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 14
Últimos 30 dias: 44
Ao todo: 957
