Ir para o conteúdo principal
Sony RM-LVR1 Motherboard Replacement
O que você precisa
    1. Sony RM-LVR1 Motherboard Replacement, Battery: passo 1, imagem 1 %32
      • Use a Phillips #00 screwdriver to remove the four (4) screws on the back of the device.
      • If the screws strips or is previously stripped, refer to the stripped screw repair guide.
      Pergunte ao FixBot
      Comentar
    2. Sony RM-LVR1 Motherboard Replacement: passo 2, imagem 1 %32
      • Battery is the rectangular and silver object in the center of device.
      • Remove battery with finger by prying at the rear.
      • If unable to remove battery, pry out using spudger.
      Pergunte ao FixBot
      Comentar
    1. Sony RM-LVR1 Motherboard Replacement, LCD Screen: passo 3, imagem 1 %32 Sony RM-LVR1 Motherboard Replacement, LCD Screen: passo 3, imagem 2 %32
      • Unscrew the 3 (three) screws holding the bracket in place.
      • Then remove the bracket by prying one end up.
      • Do not rip the ribbon cable connecting the bracket to the motherboard.
      Pergunte ao FixBot
      Comentar
    2. Sony RM-LVR1 Motherboard Replacement: passo 4, imagem 1 %32
      Ferramenta utilizada neste passo:
      • With tweezers, unplug the ribbon cable from the white connector.
      Pergunte ao FixBot
      Comentar
    3. Sony RM-LVR1 Motherboard Replacement: passo 5, imagem 1 %32
      • Remove motherboard from the device by pulling upward gently, with fingers or tweezers.
      Pergunte ao FixBot
      Comentar
    4. Sony RM-LVR1 Motherboard Replacement: passo 6, imagem 1 %32
      • Gently push out on these two clips holding the LCD to the motherboard
      • Once you have the first two off, ever so carefully, push the LCD towards the remaining two clips.
      • There is a ribbon cable underneath the LCD connecting it to the motherboard. Avoid sharp, sudden movements to prevent it from being damged
      Pergunte ao FixBot
      Comentar
    5. Sony RM-LVR1 Motherboard Replacement: passo 7, imagem 1 %32 Sony RM-LVR1 Motherboard Replacement: passo 7, imagem 2 %32
      • Undo the ribbon cable attached between the motherboard and screen by prying up black tab which holds the cable, using spudger. (See pictures)
      Pergunte ao FixBot
      Comentar
    6. Sony RM-LVR1 Motherboard Replacement: passo 8, imagem 1 %32
      • Remove the screen from the motherboard.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
1Comentário do guia
Hello
Thank you for your tutorial.
My question is about the rubber cap of the push button
Can it be changed? Spare part ?
Regards
gilbert keiser - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 27
Ao todo: 677
