Ir para o conteúdo principal
Sony BDP-S3500 Wi-Fi Module Replacement
O que você precisa
  1. Sony BDP-S3500 Wi-Fi Module Replacement, Front Panel: passo 1, imagem 1 %32 Sony BDP-S3500 Wi-Fi Module Replacement, Front Panel: passo 1, imagem 2 %32
    • Use the Phillips #2 screwdriver to remove the two 9mm screws located on the back of the device.
    Pergunte ao FixBot
    Comentar
  2. Sony BDP-S3500 Wi-Fi Module Replacement: passo 2, imagem 1 %32
    • Slide the top panel off towards the back of the device.
    • Remove the top panel.
    Pergunte ao FixBot
    Comentar
  3. Sony BDP-S3500 Wi-Fi Module Replacement: passo 3, imagem 1 %32 Sony BDP-S3500 Wi-Fi Module Replacement: passo 3, imagem 2 %32
    • Unclip the plastic tags from the bottom of the device.
    • Unclip the plastic tags from the sides of the device.
    • Slide the front panel off.
    Pergunte ao FixBot
    Comentar
  4. Sony BDP-S3500 Wi-Fi Module Replacement, Port Board: passo 4, imagem 1 %32 Sony BDP-S3500 Wi-Fi Module Replacement, Port Board: passo 4, imagem 2 %32
    • Keep the back side up and facing towards you.
    • Carefully disconnect the blue ribbon connecting the port board and motherboard.
    • Be delicate while removing the ribbon.
    Pergunte ao FixBot
    Comentar
  5. Sony BDP-S3500 Wi-Fi Module Replacement: passo 5, imagem 1 %32
    • Use a Phillips #2 screwdriver to remove the 9mm screw from the port board.
    Pergunte ao FixBot
    Comentar
  6. Sony BDP-S3500 Wi-Fi Module Replacement: passo 6, imagem 1 %32
    • Remove the port board from the device.
    Pergunte ao FixBot
    Comentar
  7. Sony BDP-S3500 Wi-Fi Module Replacement, Wi-Fi Module: passo 7, imagem 1 %32
    • Remove the white ribbon cable connecting the Wi-Fi module to the motherboard by gently pulling it out.
    Pergunte ao FixBot
    Comentar
  8. Sony BDP-S3500 Wi-Fi Module Replacement: passo 8, imagem 1 %32
    • Use a Phillips #2 screwdriver to remove the 7mm screw from the Wi-Fi module.
    Pergunte ao FixBot
    Comentar
  9. Sony BDP-S3500 Wi-Fi Module Replacement: passo 9, imagem 1 %32
    • The Wi-Fi module can now be safely removed.
    Pergunte ao FixBot
    Comentar
Conclusão
Bushra Banuso
Membro desde: 01/22/20
97 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 23
Ao todo: 729
