Ir para o conteúdo principal
Solio CLASSIC2 USB Port Replacement
O que você precisa
  1. Solio CLASSIC2 USB Port Replacement, Disconnecting the Battery: passo 1, imagem 1 %32
    • Turn off the device by pressing on the clear power button behind the device.
    • To make sure that it is off, make sure the button is not flashing green.
    Pergunte ao FixBot
    Comentar
  2. Solio CLASSIC2 USB Port Replacement: passo 2, imagem 1 %32
    • Using the Phillips #1 screwdriver, remove the 2mm screw located on the bottom of the device, near the hinge.
    Pergunte ao FixBot
    Comentar
  3. Solio CLASSIC2 USB Port Replacement: passo 3, imagem 1 %32 Solio CLASSIC2 USB Port Replacement: passo 3, imagem 2 %32 Solio CLASSIC2 USB Port Replacement: passo 3, imagem 3 %32
    • Using the plastic opening tools, gently pry open the side of the large panel.
    • Keeping the tool in, slowly slide the tool along the side of the panel.
    Pergunte ao FixBot
    Comentar
  4. Solio CLASSIC2 USB Port Replacement: passo 4, imagem 1 %32 Solio CLASSIC2 USB Port Replacement: passo 4, imagem 2 %32
    • Rotate the device 180 degrees.
    • Make sure the opening on other side of the device does not snap closed.
    • Gently slide the plastic opening tool along the side of the panel.
    Pergunte ao FixBot
    Comentar
  5. Solio CLASSIC2 USB Port Replacement: passo 5, imagem 1 %32 Solio CLASSIC2 USB Port Replacement: passo 5, imagem 2 %32
    • Do not fully pull apart the back panel from the device. Doing so can rip the two red and blue wires attached to the panel.
    • Using both hands, slowly pull apart the back panel from the rest of the device.
    • Gently flip the back panel open so the circuit board faces up and the two panels are side by side.
    Pergunte ao FixBot
    Comentar
  6. Solio CLASSIC2 USB Port Replacement: passo 6, imagem 1 %32 Solio CLASSIC2 USB Port Replacement: passo 6, imagem 2 %32
    • Softly pinch the red and blue wires close to the white connector.
    • To pull the wires out, wiggle them back and forth until the connector is fully out.
    Pergunte ao FixBot
    Comentar
  7. Solio CLASSIC2 USB Port Replacement, Circuit Board: passo 7, imagem 1 %32
    • Unscrew the three 2mm screws holding the circuit board down using a Phillips #1 screwdriver.
    Pergunte ao FixBot
    Comentar
  8. Solio CLASSIC2 USB Port Replacement: passo 8, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Make sure the white USB port cover on the side of the device is pulled out or you won't be able to lift the circuit board.
    • Gently lift the circuit board out of the device using tweezers.
    Pergunte ao FixBot
    Comentar
  9. Solio CLASSIC2 USB Port Replacement, USB Port: passo 9, imagem 1 %32
    • Soldering can melt key components and cause harm to both the user and the device. Read soldering guide before attempting.
    • Remove solder from both spots on outside of the USB port.
    • Remove solder from base of the USB port.
    Pergunte ao FixBot
    Comentar
Conclusão
Anthony Ramos
Membro desde: 10/20/13
102 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 4-28, Amido Fall 2013 Membro de Cal Poly, Team 4-28, Amido Fall 2013
CPSU-AMIDO-F13S4G28
4 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 43
Ao todo: 1,584
