Ir para o conteúdo principal
Skullcandy Hesh 3 Speaker Replacement
O que você precisa
  1. Skullcandy Hesh 3 Speaker Replacement, Speaker: passo 1, imagem 1 %32 Skullcandy Hesh 3 Speaker Replacement, Speaker: passo 1, imagem 2 %32 Skullcandy Hesh 3 Speaker Replacement, Speaker: passo 1, imagem 3 %32
    • Start by removing the earmuffs on the speaker side with the charging port. Gently pull from any point of the ear cushion, while also holding on to the base of the speaker.
    • Use a Phillips #00 screwdriver to remove all four 4.0 mm screws securing the faceplate.
    • Lastly, remove the faceplate by gently lifting it without pulling off the wires that are attached to the faceplate.
  2. Skullcandy Hesh 3 Speaker Replacement: passo 2, imagem 1 %32 Skullcandy Hesh 3 Speaker Replacement: passo 2, imagem 2 %32
    • Use a soldering iron to detach the red wire (R+) and blue wire ( R) from the motherboard.
    • The soldering iron is very hot. Be careful when using it as it can burn skin, etc. Please refer to the How to Solder and Desolder Connection guide for more information on soldering.
    • R+ should be connected to the red wire and R should be connected to the blue wire.
  3. Skullcandy Hesh 3 Speaker Replacement: passo 3, imagem 1 %32 Skullcandy Hesh 3 Speaker Replacement: passo 3, imagem 2 %32 Skullcandy Hesh 3 Speaker Replacement: passo 3, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Position the speaker so the inside is facing up.
    • Use a heat gun to warm the adhesive securing the speaker to the housing.
    • Aim the gun from a distance to prevent any damage to the plastic. Always keep the heat gun in motion while using it so one area doesn't melt.
    • Use tweezers to push the speaker through to remove it. Avoid using your hands directly on the speaker to avoid burns.
Conclusão
Emma Lyman
Membro desde: 01/17/23
385 Reputação
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 15
Duração total: 241
