Ir para o conteúdo principal
Skullcandy Hesh 3 Battery Replacement
O que você precisa
  1. Skullcandy Hesh 3 Battery Replacement, Battery: passo 1, imagem 1 %32 Skullcandy Hesh 3 Battery Replacement, Battery: passo 1, imagem 2 %32 Skullcandy Hesh 3 Battery Replacement, Battery: passo 1, imagem 3 %32
    • Start by removing the earmuffs on the speaker side with the charging port. Gently pull from any point of the ear cushion, while also holding on to the base of the speaker.
    • Use a Phillips #00 screwdriver to remove all four 4.0 mm screws securing the faceplate.
    • Remove the faceplate gently without pulling off the wires attached to the speaker and faceplate.
    Pergunte ao FixBot
    Comentar
  2. Skullcandy Hesh 3 Battery Replacement: passo 2, imagem 1 %32 Skullcandy Hesh 3 Battery Replacement: passo 2, imagem 2 %32 Skullcandy Hesh 3 Battery Replacement: passo 2, imagem 3 %32
    • Use a soldering iron to heat up the solder at the points where the red, yellow, and black wires connect until they detach from the board.
    • Lastly, lift the board gently from the ear cup to reveal the battery underneath.
    Pergunte ao FixBot
    Comentar
  3. Skullcandy Hesh 3 Battery Replacement: passo 3, imagem 1 %32 Skullcandy Hesh 3 Battery Replacement: passo 3, imagem 2 %32 Skullcandy Hesh 3 Battery Replacement: passo 3, imagem 3 %32
    • Remove the battery being held by adhesive rubber with a spudger or your hands.
    • The battery should come out with minimal force as the adhesive is not very strong.
    • When replacing with the new battery, position it in the same spot with the 3 wires sticking out from the upper left-hand corner.
    Pergunte ao FixBot
    Comentar
Conclusão
2Comentários do guia
Useful but doesn't mention battery type or where or if you can buy replacement battery.
John Layne - Responder Compartilhar
I’ve been searching the exact screw type of these because I lost 5 of them, does anyone know any specifics past 4.0 mm?
Kouroshghane - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 23
Últimos 30 dias: 121
Ao todo: 2,552
