Ir para o conteúdo principal
Skullcandy Crusher Wireless Earpiece Speaker Replacement
O que você precisa
  1. Skullcandy Crusher Wireless Earpiece Speaker Replacement, Ear Cushion: passo 1, imagem 1 %32 Skullcandy Crusher Wireless Earpiece Speaker Replacement, Ear Cushion: passo 1, imagem 2 %32
    • Take your headphones and hold them upside down for better control with your hands.
  2. Skullcandy Crusher Wireless Earpiece Speaker Replacement: passo 2, imagem 1 %32 Skullcandy Crusher Wireless Earpiece Speaker Replacement: passo 2, imagem 2 %32
    • Grab the ear cushion firmly between your thumb and forefinger with a tight grip.
    • Pull the ear cushion away from the plastic, covering the speaker, by sliding the ear cushion down to release it.
  3. Skullcandy Crusher Wireless Earpiece Speaker Replacement: passo 3, imagem 1 %32
    • Continue pulling it away from the edges of the plastic covering until the cushion is fully removed.
  4. Skullcandy Crusher Wireless Earpiece Speaker Replacement, USB Connector: passo 4, imagem 1 %32 Skullcandy Crusher Wireless Earpiece Speaker Replacement, USB Connector: passo 4, imagem 2 %32
    • Remove three 12 mm Phillips #1 screws located underneath the left ear cushion.
  5. Skullcandy Crusher Wireless Earpiece Speaker Replacement: passo 5, imagem 1 %32 Skullcandy Crusher Wireless Earpiece Speaker Replacement: passo 5, imagem 2 %32 Skullcandy Crusher Wireless Earpiece Speaker Replacement: passo 5, imagem 3 %32
    • Slide a plastic opening tool between the plastic frame and speaker assembly of the headphones.
    • Gently pry the speaker away from the frame of the headphones.
  6. Skullcandy Crusher Wireless Earpiece Speaker Replacement: passo 6, imagem 1 %32 Skullcandy Crusher Wireless Earpiece Speaker Replacement: passo 6, imagem 2 %32
    • Separate the headphone speaker assembly from headphone speaker frame.
  7. Skullcandy Crusher Wireless Earpiece Speaker Replacement: passo 7, imagem 1 %32
    • Inspect the USB port and ensure that it is connected correctly. If necessary, desolder the USB port and replace it with the new port.
    • For more information on soldering, please, use this Solder and Desolder Connections guide.
  8. Skullcandy Crusher Wireless Earpiece Speaker Replacement, Earpiece Speaker: passo 8, imagem 1 %32 Skullcandy Crusher Wireless Earpiece Speaker Replacement, Earpiece Speaker: passo 8, imagem 2 %32 Skullcandy Crusher Wireless Earpiece Speaker Replacement, Earpiece Speaker: passo 8, imagem 3 %32
    • Remove four 4 mm Phillips #1 screws that connect the motherboard with the plastic frame.
  9. Skullcandy Crusher Wireless Earpiece Speaker Replacement: passo 9, imagem 1 %32 Skullcandy Crusher Wireless Earpiece Speaker Replacement: passo 9, imagem 2 %32 Skullcandy Crusher Wireless Earpiece Speaker Replacement: passo 9, imagem 3 %32
    • Remove three 4 mm Phillips #1 screws that connect the bass speaker to the plastic frame.
  10. Skullcandy Crusher Wireless Earpiece Speaker Replacement: passo 10, imagem 1 %32 Skullcandy Crusher Wireless Earpiece Speaker Replacement: passo 10, imagem 2 %32 Skullcandy Crusher Wireless Earpiece Speaker Replacement: passo 10, imagem 3 %32
    • Move the motherboard away from the plastic frame.
    • Desolder two cables to replace the speaker and bass component.
Conclusão
Uma outra pessoa concluiu este guia.
Val
Membro desde: 03/31/22
1.125 Reputação
Autoria de 6 guias
Equipe
Um comentário
Como puedo conseguir los altavoces bajos?
Rodery Josè Garcia Hidalgo - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 25
Últimos 30 dias: 109
Duração total: 2,572
