Ir para o conteúdo principal
Skullcandy Crusher Wireless Bluetooth Antenna Replacement
O que você precisa
  1. Skullcandy Crusher Wireless Bluetooth Antenna Replacement, Ear Cushion: passo 1, imagem 1 %32 Skullcandy Crusher Wireless Bluetooth Antenna Replacement, Ear Cushion: passo 1, imagem 2 %32
    • Take your headphones and hold them upside down for better control with your hands.
  2. Skullcandy Crusher Wireless Bluetooth Antenna Replacement: passo 2, imagem 1 %32 Skullcandy Crusher Wireless Bluetooth Antenna Replacement: passo 2, imagem 2 %32
    • Grab the ear cushion firmly between your thumb and forefinger with a tight grip.
    • Pull the ear cushion away from the plastic, covering the speaker, by sliding the ear cushion down to release it.
  3. Skullcandy Crusher Wireless Bluetooth Antenna Replacement: passo 3, imagem 1 %32
    • Continue pulling it away from the edges of the plastic covering until the cushion is fully removed.
  4. Skullcandy Crusher Wireless Bluetooth Antenna Replacement, Bluetooth Antenna: passo 4, imagem 1 %32 Skullcandy Crusher Wireless Bluetooth Antenna Replacement, Bluetooth Antenna: passo 4, imagem 2 %32
    • Remove three 12 mm Phillips #1 screws located underneath the left ear cushion of the headphones.
  5. Skullcandy Crusher Wireless Bluetooth Antenna Replacement: passo 5, imagem 1 %32 Skullcandy Crusher Wireless Bluetooth Antenna Replacement: passo 5, imagem 2 %32 Skullcandy Crusher Wireless Bluetooth Antenna Replacement: passo 5, imagem 3 %32
    • Slide a plastic opening tool between the plastic frame and speaker assembly of the headphones.
    • Gently pry the speaker assembly away from the frame of the headphones.
  6. Skullcandy Crusher Wireless Bluetooth Antenna Replacement: passo 6, imagem 1 %32 Skullcandy Crusher Wireless Bluetooth Antenna Replacement: passo 6, imagem 2 %32
    • Separate headphone speaker assembly from headphone speaker frame.
  7. Skullcandy Crusher Wireless Bluetooth Antenna Replacement: passo 7, imagem 1 %32
    • The Bluetooth antenna module chip is located on the right top corner of the motherboard.
    • If necessary, the chip module can be desoldered and replaced with a new one. Or, the motherboard can be replaced.
    • For more information on soldering, please, use this Solder and Desolder Connections guide.
Conclusão
Uma outra pessoa concluiu este guia.
Val
Membro desde: 03/31/22
1.104 Reputação
Autoria de 6 guias
Equipe
Um comentário
Where can one purchase a replacement chip?
Josh - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 7
Últimos 30 dias: 50
Duração total: 1,023
