Ir para o conteúdo principal
Skullcandy Crusher Wireless Battery Replacement
O que você precisa
  1. Skullcandy Crusher Wireless Battery Replacement, Ear Cushion: passo 1, imagem 1 %32 Skullcandy Crusher Wireless Battery Replacement, Ear Cushion: passo 1, imagem 2 %32
    • Take your headphones and hold them upside down for better control with your hands.
  2. Skullcandy Crusher Wireless Battery Replacement: passo 2, imagem 1 %32 Skullcandy Crusher Wireless Battery Replacement: passo 2, imagem 2 %32
    • Grab the ear cushion firmly between your thumb and forefinger with a tight grip.
    • Pull the ear cushion away from the plastic, covering the speaker, by sliding the ear cushion down to release it.
  3. Skullcandy Crusher Wireless Battery Replacement: passo 3, imagem 1 %32
    • Continue pulling it away from the edges of the plastic covering until the cushion is fully removed.
  4. Skullcandy Crusher Wireless Battery Replacement, Battery: passo 4, imagem 1 %32 Skullcandy Crusher Wireless Battery Replacement, Battery: passo 4, imagem 2 %32
    • Remove three 12 mm Phillips #1 screws located underneath the left ear cushion of the headphones.
    • You have to work on the right-side earphone.
  5. Skullcandy Crusher Wireless Battery Replacement: passo 5, imagem 1 %32 Skullcandy Crusher Wireless Battery Replacement: passo 5, imagem 2 %32 Skullcandy Crusher Wireless Battery Replacement: passo 5, imagem 3 %32
    • Slide a plastic opening tool between the plastic frame and speaker assembly of the headphones.
    • Gently pry the speaker part away from the frame of the headphones.
  6. Skullcandy Crusher Wireless Battery Replacement: passo 6, imagem 1 %32 Skullcandy Crusher Wireless Battery Replacement: passo 6, imagem 2 %32
    • Separate the headphone speaker assembly from the headphone speaker frame.
  7. Skullcandy Crusher Wireless Battery Replacement: passo 7, imagem 1 %32 Skullcandy Crusher Wireless Battery Replacement: passo 7, imagem 2 %32 Skullcandy Crusher Wireless Battery Replacement: passo 7, imagem 3 %32
    • Remove the battery from the headphone housing.
    • Use a soldering iron to desolder the black, red, and yellow cables from the board and disconnect the battery.
    • For more information on soldering, please, use this Solder and Desolder Connections guide.
Conclusão
6 outras pessoas executaram este guia.
Val
Membro desde: 03/31/22
1.227 Reputação
Autoria de 6 guias
Equipe
5Comentários do guia
Hi, Can you specify this replacement batterys name and model number?
kituserkituserkituser kit - Responder Compartilhar
1050mAh, 3,7V 3,885Wh
Mika Björn Wilhelmsen - Responder Compartilhar
Which battery should i buy for my skull candy hes evo??
Lakshit Meena - Responder Compartilhar
donde puedo conseguir la bateria de los skullcandy crusher?
y cual bateria lleva?
pedro landeros - Responder Compartilhar
Am I able to send my headphones to you to be fixed?
If I can, what would the cost be?
I have two headphone sets
Jeffrey Timothy Valerie - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 34
Últimos 30 dias: 177
Ao todo: 15,179
