Ir para o conteúdo principal
Singer Simple Sewing Machine (Model 2263) Needle Replacement
O que você precisa
  1. Singer Simple Sewing Machine (Model 2263) Needle Replacement, Needle: passo 1, imagem 1 %32
    • Turn off the sewing machine and unplug it.
    Pergunte ao FixBot
    Comentar
  2. Singer Simple Sewing Machine (Model 2263) Needle Replacement: passo 2, imagem 1 %32
    • Push the back lever up and remove the presser foot.
    Pergunte ao FixBot
    Comentar
  3. Singer Simple Sewing Machine (Model 2263) Needle Replacement: passo 3, imagem 1 %32
    • Raise the needle bar by turning the handwheel toward you.
    Pergunte ao FixBot
    Comentar
  4. Singer Simple Sewing Machine (Model 2263) Needle Replacement: passo 4, imagem 1 %32
    • With the provided Singer screwdriver or a flat-head screwdriver, loosen the clamp screw by turning it toward you.
    Pergunte ao FixBot
    Comentar
  5. Singer Simple Sewing Machine (Model 2263) Needle Replacement: passo 5, imagem 1 %32
    • Remove the broken needle.
    Pergunte ao FixBot
    Comentar
  6. Singer Simple Sewing Machine (Model 2263) Needle Replacement: passo 6, imagem 1 %32 Singer Simple Sewing Machine (Model 2263) Needle Replacement: passo 6, imagem 2 %32
    • Insert the new needle with the flat side (the side with the numbers) facing the back of the sewing machine. Tighten the clamp screw by turning it toward the back.
    Pergunte ao FixBot
    Comentar
  7. Singer Simple Sewing Machine (Model 2263) Needle Replacement: passo 7, imagem 1 %32 Singer Simple Sewing Machine (Model 2263) Needle Replacement: passo 7, imagem 2 %32
    • Put the presser foot back on by pushing the back lever up and guiding the bar on the presser foot onto the hook of the needle bar. Release the lever to secure.
    Pergunte ao FixBot
    Comentar
Conclusão
Once the pressure foot is attached, thread the needle before plugging in the sewing machine and turning it on.
Renee Allred
Membro desde: 09/15/23
145 Reputação
Autoria de 1 guia
1Comentário do guia
Please assist me with adjusting needle bar height for Singer Simple 2263 cannot find how to adjust hook timing either have watched sooo many videos none have helped me
Maria L. Soto - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 8
Últimos 7 dias: 29
Últimos 30 dias: 127
Ao todo: 1,828
