Ir para o conteúdo principal
Shark Flex DuoClean Motor Replacement
O que você precisa
  1. Shark Flex DuoClean Motor Replacement, Garage Door: passo 1, imagem 1 %32 Shark Flex DuoClean Motor Replacement, Garage Door: passo 1, imagem 2 %32
    • Open the garage door by sliding both of the release buttons away from you.
    • Lift off the garage door.
    Pergunte ao FixBot
    Comentar
  2. Shark Flex DuoClean Motor Replacement, Side Component: passo 2, imagem 1 %32 Shark Flex DuoClean Motor Replacement, Side Component: passo 2, imagem 2 %32
    • Remove the plastic screw covering using a metal spudger by pushing the sharp side into the crevice and prying the cover out.
    Pergunte ao FixBot
    Comentar
  3. Shark Flex DuoClean Motor Replacement: passo 3, imagem 1 %32 Shark Flex DuoClean Motor Replacement: passo 3, imagem 2 %32
    • Turn the T10 Security Torx screwdriver counterclockwise to remove the 15mm screw.
    Pergunte ao FixBot
    Comentar
  4. Shark Flex DuoClean Motor Replacement: passo 4, imagem 1 %32
    • Use the iFixit Opening Tool to pry the side of the vacuum open.
    Pergunte ao FixBot
    Comentar
  5. Shark Flex DuoClean Motor Replacement: passo 5, imagem 1 %32
    • Remove the side component with your hands.
    Pergunte ao FixBot
    Comentar
  6. Shark Flex DuoClean Motor Replacement, Top Component: passo 6, imagem 1 %32
    • Remove the four 15 mm T10 screws on the underside of the vacuum.
    Pergunte ao FixBot
    Comentar
  7. Shark Flex DuoClean Motor Replacement: passo 7, imagem 1 %32 Shark Flex DuoClean Motor Replacement: passo 7, imagem 2 %32
    • Using the plastic spudger, pry the back seam of the top component to pop it off the vacuum.
    Pergunte ao FixBot
    Comentar
  8. Shark Flex DuoClean Motor Replacement, Brush Motor: passo 8, imagem 1 %32 Shark Flex DuoClean Motor Replacement, Brush Motor: passo 8, imagem 2 %32
    • Orient the vacuum so you are looking down at the open garage of the vacuum.
    • Using your right hand, rotate the top of the silver motor towards the brush roll of the vacuum so the motor fits through the opening.
    Pergunte ao FixBot
    Comentar
  9. Shark Flex DuoClean Motor Replacement: passo 9, imagem 1 %32
    • With both thumbs, push the gear on the right side of the motor into the vacuum. The motor should pop out.
    • Slowly pull the motor out of the vacuum base and reveal the electrical cords.
    Pergunte ao FixBot
    Comentar
  10. Shark Flex DuoClean Motor Replacement: passo 10, imagem 1 %32
    • To fully remove the motor, cut the wires.
    • For reassembly, use the soldering guide in the Introduction.
    Pergunte ao FixBot
    Comentar
Conclusão
6 outras pessoas executaram este guia.
Equipe
Cal Poly, Team S17-G5, White Fall 2018 Membro de Cal Poly, Team S17-G5, White Fall 2018
CPSU-WHITE-F18S17G5
4 Membros
Autoria de 25 guias
7Comentários do guia
Can this motor we test it before taking it out
craigfranz - Responder Compartilhar
Can this motor be tested before taking it out?
How do I know if the motor is burned out
Danny Manuele - Responder Compartilhar
Will you be able to take out the brush roll in front of the motor?
CAM BAP - Responder Compartilhar
Great fix. I wonder if you know how to find a replacement motor? My Dyson motor died and I’m not sure where to start looking for a replacement part - Dyson don’t sell it.
TyN - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 24
Últimos 30 dias: 94
Ao todo: 24,846
