Ir para o conteúdo principal
Shark Flex DuoClean LED Headlight Replacement
O que você precisa
  1. Shark Flex DuoClean LED Headlight Replacement, Garage Door: passo 1, imagem 1 %32 Shark Flex DuoClean LED Headlight Replacement, Garage Door: passo 1, imagem 2 %32
    • Open the garage door by sliding both of the release buttons away from you.
    • Lift off the garage door.
    Pergunte ao FixBot
    Comentar
  2. Shark Flex DuoClean LED Headlight Replacement, Side Component: passo 2, imagem 1 %32 Shark Flex DuoClean LED Headlight Replacement, Side Component: passo 2, imagem 2 %32
    • Remove the plastic screw covering using a metal spudger by pushing the sharp side into the crevice and prying the cover out.
    Pergunte ao FixBot
    Comentar
  3. Shark Flex DuoClean LED Headlight Replacement: passo 3, imagem 1 %32 Shark Flex DuoClean LED Headlight Replacement: passo 3, imagem 2 %32
    • Turn the T10 Security Torx screwdriver counterclockwise to remove the 15mm screw.
    Pergunte ao FixBot
    Comentar
  4. Shark Flex DuoClean LED Headlight Replacement: passo 4, imagem 1 %32
    • Use the iFixit Opening Tool to pry the side of the vacuum open.
    Pergunte ao FixBot
    Comentar
  5. Shark Flex DuoClean LED Headlight Replacement: passo 5, imagem 1 %32
    • Remove the side component with your hands.
    Pergunte ao FixBot
    Comentar
  6. Shark Flex DuoClean LED Headlight Replacement, LED Headlight: passo 6, imagem 1 %32
    Pergunte ao FixBot
    Comentar
  7. Shark Flex DuoClean LED Headlight Replacement: passo 7, imagem 1 %32 Shark Flex DuoClean LED Headlight Replacement: passo 7, imagem 2 %32
    • Use the nylon spudger to pry the gold, plastic cover off of the headlights.
    • Prying off the cover too aggressively may cause it to break.
    Pergunte ao FixBot
    Comentar
  8. Shark Flex DuoClean LED Headlight Replacement: passo 8, imagem 1 %32 Shark Flex DuoClean LED Headlight Replacement: passo 8, imagem 2 %32
    Pergunte ao FixBot
    Comentar
  9. Shark Flex DuoClean LED Headlight Replacement: passo 9, imagem 1 %32 Shark Flex DuoClean LED Headlight Replacement: passo 9, imagem 2 %32
    • Use the metal spudger to pry off the clear, plastic cover on the LEDs.
    • Prying the cover off too aggressively may cause it to break.
    Pergunte ao FixBot
    Comentar
  10. Shark Flex DuoClean LED Headlight Replacement: passo 10, imagem 1 %32
    • Use wire cutters to detach the black cables from the LEDs on both sides.
    • Strip 1 cm off the ends of the wires, using a wire stripper.
    • Solder the exposed wires to the new LEDs.
    • Use the soldering guide in the Introduction.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
Cal Poly, Team S17-G5, White Fall 2018 Membro de Cal Poly, Team S17-G5, White Fall 2018
CPSU-WHITE-F18S17G5
4 Membros
Autoria de 25 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 18
Ao todo: 1,825
