Ir para o conteúdo principal
Set-Top Box Numb Button Replacement
O que você precisa
    1. Set-Top Box Numb Button Replacement, Numb Button: passo 1, imagem 1 %32 Set-Top Box Numb Button Replacement, Numb Button: passo 1, imagem 2 %32 Set-Top Box Numb Button Replacement, Numb Button: passo 1, imagem 3 %32
      • Make sure the box is not plugged in before starting!
      • Remove the 5 screws holding the outer casing in place: 3 can be found on the back and 1 on either side of the box.
      • Slide the casing backwards.
      Pergunte ao FixBot
      Comentar
    2. Set-Top Box Numb Button Replacement: passo 2, imagem 1 %32 Set-Top Box Numb Button Replacement: passo 2, imagem 2 %32 Set-Top Box Numb Button Replacement: passo 2, imagem 3 %32
      • Disconnect the front of the by lifting the 2 connectors . You can also apply extra pressure on the front from below.
      • Tilt the front forward and remove it.
      • Remove the connector by pressing the upper part of it and carefully pulling it.
      • Be carefull not to damage the cables and circuit board!
      Pergunte ao FixBot
      Comentar
    3. Set-Top Box Numb Button Replacement: passo 3, imagem 1 %32 Set-Top Box Numb Button Replacement: passo 3, imagem 2 %32 Set-Top Box Numb Button Replacement: passo 3, imagem 3 %32
      • Undo the 4 screws of the front panel.
      • Locate your broken button. For instance, the third button from the left (front view), is the CH- button.
      Pergunte ao FixBot
      Comentar
    4. Set-Top Box Numb Button Replacement: passo 4, imagem 1 %32 Set-Top Box Numb Button Replacement: passo 4, imagem 2 %32 Set-Top Box Numb Button Replacement: passo 4, imagem 3 %32
      • Unsolder the push button. You can push it out or maybe use some plyers.
      • Remove the old button and insert the new one.
      • Solder the new push button on.
      • Check this link for help Como soldar e dessoldar contatos
      Pergunte ao FixBot
      Comentar
Conclusão
Yvo Kipping
Membro desde: 12/05/16
101 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 17
Ao todo: 741
