Ir para o conteúdo principal
Sanyo VPC-S1415 LCD Replacement
O que você precisa
    1. Sanyo VPC-S1415 LCD Replacement, LCD: passo 1, imagem 1 %32 Sanyo VPC-S1415 LCD Replacement, LCD: passo 1, imagem 2 %32 Sanyo VPC-S1415 LCD Replacement, LCD: passo 1, imagem 3 %32
      Ferramenta utilizada neste passo:
      • Here is a recently acquired camera. Initial cost $3.00
      • Only trouble is, obviously broken LCD
      • Remove the carrying strip. Use a needle and some tweezers to loosen the slip knot.
      Pergunte ao FixBot
      Comentar
    2. Sanyo VPC-S1415 LCD Replacement: passo 2, imagem 1 %32 Sanyo VPC-S1415 LCD Replacement: passo 2, imagem 2 %32 Sanyo VPC-S1415 LCD Replacement: passo 2, imagem 3 %32
      • Remove one screw on the right of the camera
      • Remove one screw on the left side of the camera
      • Remove the two screws on the bottom
      Pergunte ao FixBot
      Comentar
    3. Sanyo VPC-S1415 LCD Replacement: passo 3, imagem 1 %32 Sanyo VPC-S1415 LCD Replacement: passo 3, imagem 2 %32 Sanyo VPC-S1415 LCD Replacement: passo 3, imagem 3 %32
      • Split the camera from the battery compartment down. You can use an opening tools, or just your fingernails, if so equipped.
      • This will remove the front part of the case.
      • Remove this screw on the right side of the camera. Keep it separate from the 4 screws previously removed. The are of different length
      Pergunte ao FixBot
      Comentar
    4. Sanyo VPC-S1415 LCD Replacement: passo 4, imagem 1 %32 Sanyo VPC-S1415 LCD Replacement: passo 4, imagem 2 %32 Sanyo VPC-S1415 LCD Replacement: passo 4, imagem 3 %32
      • Remove the screw on the bottom of the battery compartment. Keep this screw with the one removed on the previous step. These two screws have a different length than all the other screws. They are the shortest ones in the camera
      • With those two screws removed, you can not separate the back part of the case.
      • Flip the LCD to the right and out of the frame. Do NOT try to remove it yet.
      • Remove the screw screws that hold the LCD frame to the logic board. Keep the 3 screws separated from the rest of the screws, due to different length.
      Pergunte ao FixBot
      Comentar
    5. Sanyo VPC-S1415 LCD Replacement: passo 5, imagem 1 %32 Sanyo VPC-S1415 LCD Replacement: passo 5, imagem 2 %32 Sanyo VPC-S1415 LCD Replacement: passo 5, imagem 3 %32
      • With the frame removed, the connector and LCD cable are now fully accessible. Note the to tabs on the cable and their position on the logic board.
      • Flip the tab on the connector carefully up and remove the LCD.
      • Hopefully this is what you will get after replacing the LCD and reassembling the camera in reverse order. Total replacement cost was $15 and 30 minutes of my time.
      Pergunte ao FixBot
      Comentar
Conclusão
oldturkey03
Membro desde: 09/29/10
858.690 Reputação
Autoria de 123 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 33
Ao todo: 2,673
