Ir para o conteúdo principal
Samsung Watch Active Sensor Array Replacement
O que você precisa
  1. Samsung Watch Active Sensor Array Replacement, Turn off the watch: passo 1, imagem 1 %32 Samsung Watch Active Sensor Array Replacement, Turn off the watch: passo 1, imagem 2 %32
    • Turn off the Galaxy Watch Active by pushing and holding the bottom button for approximately 3 seconds. You should feel a short vibration.
    • When the "Power off" symbol appears tap the center of the screen to make it shut down. You should feel a longer vibration for confirmation.
    Pergunte ao FixBot
    Comentar
  2. Samsung Watch Active Sensor Array Replacement, Remove the rear screws: passo 2, imagem 1 %32
    • Use a Tri-point Y00 screwdriver to remove the four 4 mm-long screws on the back of the watch.
    Pergunte ao FixBot
    Comentar
  3. Samsung Watch Active Sensor Array Replacement, Separate the back cover from the housing: passo 3, imagem 1 %32 Samsung Watch Active Sensor Array Replacement, Separate the back cover from the housing: passo 3, imagem 2 %32 Samsung Watch Active Sensor Array Replacement, Separate the back cover from the housing: passo 3, imagem 3 %32
    • Use an opening tool and place it between the plastic back cover and the metal housing near the buttons.
    • Push the tip of the opening tool into the gap to separate the back cover from the housing.
    • Don’t remove the back cover all the way yet. There is a cable connecting it to the motherboard.
    Pergunte ao FixBot
    Comentar
  4. Samsung Watch Active Sensor Array Replacement, Disconnect the sensor array: passo 4, imagem 1 %32 Samsung Watch Active Sensor Array Replacement, Disconnect the sensor array: passo 4, imagem 2 %32
    • Carefully lift the back cover approximately 2 cm to access the sensor array connector near the two buttons.
    • Use a spudger to disconnect the sensor array from the motherboard.
    Pergunte ao FixBot
    Comentar
  5. Samsung Watch Active Sensor Array Replacement, Remove the back cover: passo 5, imagem 1 %32
    • Remove the back cover.
    Pergunte ao FixBot
    Comentar
  6. Samsung Watch Active Sensor Array Replacement, Loosen the sensor array: passo 6, imagem 1 %32 Samsung Watch Active Sensor Array Replacement, Loosen the sensor array: passo 6, imagem 2 %32 Samsung Watch Active Sensor Array Replacement, Loosen the sensor array: passo 6, imagem 3 %32
    • Use an opening pick and slide it underneath the sensor array which is slightly glued in place.
    • Carefully twist the opening pick to separate the sensor array from the back cover.
    Pergunte ao FixBot
    Comentar
  7. Samsung Watch Active Sensor Array Replacement, Remove the sensor array: passo 7, imagem 1 %32 Samsung Watch Active Sensor Array Replacement, Remove the sensor array: passo 7, imagem 2 %32
    • Remove the sensor array from the back cover.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Tobias Isakeit
Membro desde: 03/31/14
133.802 Reputação
Autoria de 189 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 10
Últimos 30 dias: 50
Ao todo: 4,838
