Ir para o conteúdo principal
Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker)
O que você precisa
  1. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Unplug your refrigerator: passo 1, imagem 1 %32
    • Unplug your refrigerator before you begin your repair.
    Pergunte ao FixBot
    Comentar
  2. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Open the freezer drawer: passo 2, imagem 1 %32 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Open the freezer drawer: passo 2, imagem 2 %32
    • Slide the freezer drawer fully open.
    Pergunte ao FixBot
    Comentar
  3. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Remove the freezer bins: passo 3, imagem 1 %32 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Remove the freezer bins: passo 3, imagem 2 %32 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Remove the freezer bins: passo 3, imagem 3 %32
    • Lift and remove all the freezer bins from the drawer.
    • You may need to open the refrigerator doors in order to remove the large bin.
    Pergunte ao FixBot
    Comentar
  4. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Remove the freezer door: passo 4, imagem 1 %32 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Remove the freezer door: passo 4, imagem 2 %32 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Remove the freezer door: passo 4, imagem 3 %32
    • A plastic tab locks each drawer rail in place.
    • Use a flathead screwdriver or your fingers to press in the plastic tab near the inner end of the drawer rail.
    • As you press the plastic tab, grasp the rail with your free hand and slide it towards you slightly to unlock the rail.
    Pergunte ao FixBot
    Comentar
  5. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker): passo 5, imagem 1 %32 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker): passo 5, imagem 2 %32
    • Repeat the rail unlock procedure on the other drawer rail.
    • Once both rails are unlocked, firmly pull both rails to slide them out of the refrigerator wall guides.
    • Remove the freezer drawer.
    • To install the freezer drawer:
    • Push the geared torsion bar until it rests at the very end of the rails.
    • Align the drawer rails to the refrigerator wall guides.
    • Close the freezer drawer until the rails lock back in place.
    • If you don't hear a click, visually check if the plastic tabs have locked in place. You may need to push the rails in a little further with your fingers to set the tabs.
    Pergunte ao FixBot
    Comentar
  6. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Unfasten the icemaker assembly: passo 6, imagem 1 %32 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Unfasten the icemaker assembly: passo 6, imagem 2 %32
    • Use a Phillips screwdriver to remove the screws securing the icemaker assembly to the freezer ceiling.
    Pergunte ao FixBot
    Comentar
  7. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Disconnect the icemaker assembly: passo 7, imagem 1 %32 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Disconnect the icemaker assembly: passo 7, imagem 2 %32
    • Grasp the front edge of the icemaker assembly and tilt it downwards.
    • Don't try to remove the icemaker yet, as it's still connected by a few wires.
    Pergunte ao FixBot
    Comentar
  8. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker): passo 8, imagem 1 %32 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker): passo 8, imagem 2 %32
    • Use your fingers to guide the wire harness out of the icemaker assembly.
    Pergunte ao FixBot
    Comentar
  9. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker): passo 9, imagem 1 %32 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker): passo 9, imagem 2 %32 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker): passo 9, imagem 3 %32
    • Squeeze the icemaker cable connector and pull to disconnect it.
    Pergunte ao FixBot
    Comentar
  10. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker): passo 10, imagem 1 %32
    • Remove the icemaker assembly.
    Pergunte ao FixBot
    Comentar
Conclusão
Repair didn’t go as planned? Ask our Answers community for help.
Arthur Shi
Membro desde: 01/03/18
343.657 Reputação
Autoria de 915 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 27.751 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 32
Últimos 30 dias: 139
Ao todo: 2,136
