Ir para o conteúdo principal
Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement
O que você precisa
  1. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Unplug your refrigerator: passo 1, imagem 1 %32
    • Unplug your refrigerator before you begin your repair.
  2. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Open the freezer drawer: passo 2, imagem 1 %32 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Open the freezer drawer: passo 2, imagem 2 %32
    • Slide the freezer drawer fully open.
  3. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Remove the freezer bins: passo 3, imagem 1 %32 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Remove the freezer bins: passo 3, imagem 2 %32 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Remove the freezer bins: passo 3, imagem 3 %32
    • Lift and remove all the freezer bins from the drawer.
    • You may need to open the refrigerator doors in order to remove the large bin.
  4. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Remove the freezer door: passo 4, imagem 1 %32 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Remove the freezer door: passo 4, imagem 2 %32 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Remove the freezer door: passo 4, imagem 3 %32
    • A plastic tab locks each drawer rail in place.
    • Use a flathead screwdriver or your fingers to press in the plastic tab near the inner end of the drawer rail.
    • While pressing the plastic tab, grasp the rail with your free hand and slide it towards you slightly to unlock the rail.
  5. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement: passo 5, imagem 1 %32
    • Repeat the rail unlock procedure on the other drawer rail.
  6. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement: passo 6, imagem 1 %32
    • Once both rails are unlocked, firmly pull both rails to slide them out of the refrigerator wall guides.
    • Remove the freezer drawer.
    • To reinstall the freezer drawer:
    • Push the geared torsion bar until it rests at the very end of the rails.
    • Align the drawer rails to the refrigerator wall guides.
    • Close the freezer drawer until the rails lock back in place.
    • If you don't hear a click, visually check if the plastic tabs have locked in place. You may need to push the rails in a little further with your fingers to set the tabs.
  7. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Remove the evaporator cover: passo 7, imagem 1 %32
    • Use a Phillips screwdriver to remove the two 18.5 mm‑long screws securing the evaporator cover to the refrigerator.
  8. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement: passo 8, imagem 1 %32 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement: passo 8, imagem 2 %32
    • Lift the bottom edge of the evaporator cover away from the refrigerator to release the bottom clips.
    • Don't try to fully remove the cover. It's still connected by a few wires.
    • Shift the evaporator cover downwards to access the connectors in the top right corner of the freezer compartment.
  9. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Disconnect the fan connector: passo 9, imagem 1 %32 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Disconnect the fan connector: passo 9, imagem 2 %32 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Disconnect the fan connector: passo 9, imagem 3 %32
    • Squeeze the bottom edge of the fan connector to unlock it from the freezer wall.
    • Pull and disconnect the fan connector.
  10. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Remove the evaporator cover: passo 10, imagem 1 %32
    • Remove the evaporator cover.
  11. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Loosen the fan cable: passo 11, imagem 1 %32 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Loosen the fan cable: passo 11, imagem 2 %32 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Loosen the fan cable: passo 11, imagem 3 %32
    • Guide the fan cable out of the evaporator cover clips.
    • If you have trouble getting the cable out of the clips, squeeze the clips with pliers to create a wider gap.
  12. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Remove the evaporator back panel: passo 12, imagem 1 %32
    • Use a Phillips screwdriver to remove the five 14.5 mm‑long screws securing the back panel to the evaporator cover.
  13. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement: passo 13, imagem 1 %32 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement: passo 13, imagem 2 %32 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement: passo 13, imagem 3 %32
    • Use your fingers to pry and release the clips along the short edge of the evaporator cover.
    • If the perimeter foam insulation prevents you from releasing the clips, cut the foam with scissors.
  14. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement: passo 14, imagem 1 %32 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement: passo 14, imagem 2 %32 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement: passo 14, imagem 3 %32
    • Lift and separate the back panel from the evaporator cover.
  15. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Remove the evaporator fan: passo 15, imagem 1 %32
    • Use a Phillips screwdriver to remove the three 14.2 mm‑long screws securing the evaporator fan.
  16. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement: passo 16, imagem 1 %32 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement: passo 16, imagem 2 %32
    • Lift and remove the evaporator fan.
    • During reassembly, be sure to install the fan in the right orientation: the side with the center label should face down towards the evaporator cover.
Conclusão
Arthur Shi
Membro desde: 01/03/18
258.910 Reputação
Autoria de 531 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 140
Autoria de 18.077 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 46
Últimos 30 dias: 183
Duração total: 1,356
