Ir para o conteúdo principal
Samsung RF28R7351 Fuse Block Module Replacement
O que você precisa
Vídeo de Apresentação
    1. Samsung RF28R7351 Fuse Block Module Replacement, Fuse Box Module: passo 1, imagem 1 %32
      • Begin by disconnecting the power to the appliance
      • It is also recommended to test the outlet for the proper voltage
      • Also, turn off the water.
      Pergunte ao FixBot
      Comentar
    2. Samsung RF28R7351 Fuse Block Module Replacement: passo 2, imagem 1 %32
      • You will need a Phillips screwdriver to remove the cover, which is held on by five Phillips screws.
      • Remove the five Phillips screws.
      • The lower middle screw is a machine screw thread, so keep it separate for reinstallation.
      Pergunte ao FixBot
      Comentar
    3. Pergunte ao FixBot
      Comentar
    4. Samsung RF28R7351 Fuse Block Module Replacement: passo 4, imagem 1 %32 Samsung RF28R7351 Fuse Block Module Replacement: passo 4, imagem 2 %32
      • With the panel removed, you now have clear access to the fuse block.
      Pergunte ao FixBot
      Comentar
    5. Samsung RF28R7351 Fuse Block Module Replacement, Test continuity of fuses: passo 5, imagem 1 %32 Samsung RF28R7351 Fuse Block Module Replacement, Test continuity of fuses: passo 5, imagem 2 %32
      • The main reason why you'd be accessing your fuse block is if the unit has no power
      • Once the fuse block is removed, you can use your multimeter to test continuity on the metal sides of each one of these fuses.
      • (How to use a multimeter)
      • If one is blown, the fuse block will need to be replaced.
      Pergunte ao FixBot
      Comentar
    6. Samsung RF28R7351 Fuse Block Module Replacement, Disconnecting the fuse block: passo 6, imagem 1 %32 Samsung RF28R7351 Fuse Block Module Replacement, Disconnecting the fuse block: passo 6, imagem 2 %32
      Pergunte ao FixBot
      Comentar
    7. Samsung RF28R7351 Fuse Block Module Replacement, Installing a new fuse block: passo 7, imagem 1 %32 Samsung RF28R7351 Fuse Block Module Replacement, Installing a new fuse block: passo 7, imagem 2 %32
      • When installing your new fuse block, first install the wiring.
      • Make sure the connector is securely locked into place.
      • The red wire goes with the red, and the blue with the blue.
      • Swing it in at an angle and pop it in place.
      Pergunte ao FixBot
      Comentar
    8. Samsung RF28R7351 Fuse Block Module Replacement, Reinstall the panel cover: passo 8, imagem 1 %32
      • Once the new fuse block is installed, you can reinstall the panel cover.
      • To reinstall your panel cover, first bring in the top at an angle and drop it on those hooks.
      Pergunte ao FixBot
      Comentar
    9. Samsung RF28R7351 Fuse Block Module Replacement: passo 9, imagem 1 %32 Samsung RF28R7351 Fuse Block Module Replacement: passo 9, imagem 2 %32 Samsung RF28R7351 Fuse Block Module Replacement: passo 9, imagem 3 %32
      Pergunte ao FixBot
      Comentar
Linha de Chegada
eCuration
Membro desde: 05/19/17
478.744 Reputação
Autoria de 396 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 13
Últimos 30 dias: 51
Ao todo: 790
