Ir para o conteúdo principal
Samsung RC512 Screen Replacement
O que você precisa
  1. Samsung RC512 Screen Replacement, Battery: passo 1, imagem 1 %32
    • Place the laptop upside down.
    Pergunte ao FixBot
    Comentar
  2. Samsung RC512 Screen Replacement: passo 2, imagem 1 %32 Samsung RC512 Screen Replacement: passo 2, imagem 2 %32
    • Locate two notches above the battery.
    • Slide both battery locking notches to either side to remove the battery.
    • Pull the battery out.
    Pergunte ao FixBot
    Comentar
  3. Samsung RC512 Screen Replacement, Screen: passo 3, imagem 1 %32 Samsung RC512 Screen Replacement, Screen: passo 3, imagem 2 %32 Samsung RC512 Screen Replacement, Screen: passo 3, imagem 3 %32
    • The Laptop should be off before removing the battery.
    Pergunte ao FixBot
    Comentar
  4. Samsung RC512 Screen Replacement: passo 4, imagem 1 %32 Samsung RC512 Screen Replacement: passo 4, imagem 2 %32 Samsung RC512 Screen Replacement: passo 4, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Remove the gray covers with tweezers to expose the 4mm screws.
    • Using a Phillips #0 screwdriver, remove the four 4 mm Phillips #0 screws.
    Pergunte ao FixBot
    Comentar
  5. Samsung RC512 Screen Replacement: passo 5, imagem 1 %32 Samsung RC512 Screen Replacement: passo 5, imagem 2 %32
    • Insert the blue plastic opening tool into the bezel and rear housing of the screen.
    • Use the plastic opening tool to pop open the claps that hold the casing on the screen.
    • Work your way around the sides carefully and continue this to the bottom.
    • You may use your fingers to help remove the cover.
    Pergunte ao FixBot
    Comentar
  6. Samsung RC512 Screen Replacement: passo 6, imagem 1 %32 Samsung RC512 Screen Replacement: passo 6, imagem 2 %32
    • With the Phillips #0 screwdriver remove the six 3 mm screws, which mount the screen onto the base of the laptop.
    • As you remove the last two screws, support the screen. As the screws are taken out, the screen will begin to fall forward.
    Pergunte ao FixBot
    Comentar
  7. Samsung RC512 Screen Replacement: passo 7, imagem 1 %32 Samsung RC512 Screen Replacement: passo 7, imagem 2 %32 Samsung RC512 Screen Replacement: passo 7, imagem 3 %32
    • Gently lay the LCD onto the keyboard.
    • Do not separate the LCD screen and the back panel from each other. The video connector still connects the two together.
    • Remove the tape that secures the video connector to the LCD screen with tweezers.
    • Grasp the video connector at its base and pull it away from the LCD screen.
    • The only thing holding the screen will be the clear tape causing it to come out easily.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
jando
Membro desde: 09/15/16
917 Reputação
Autoria de 8 guias
Equipe
USF Tampa, Team 18-2, Blackwell Fall 2016 Membro de USF Tampa, Team 18-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S18G2
4 Membros
Autoria de 8 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 22
Ao todo: 1,065
