Ir para o conteúdo principal
Samsung NX30 Flash Replacement
O que você precisa
  1. Samsung NX30 Flash Replacement, Battery: passo 1, imagem 1 %32
    • Flip the camera over so that the bottom of the camera is up.
    • Push the battery switch towards the back of the camera.
    Pergunte ao FixBot
    Comentar
  2. Samsung NX30 Flash Replacement: passo 2, imagem 1 %32 Samsung NX30 Flash Replacement: passo 2, imagem 2 %32
    • Locate the blue switch above the battery pack.
    • Slide the blue switch into the camera in the direction of the arrow on the switch. When the switch has been pushed in the battery will spring up.
    Pergunte ao FixBot
    Comentar
  3. Samsung NX30 Flash Replacement: passo 3, imagem 1 %32
    • Pull the battery out.
    Pergunte ao FixBot
    Comentar
  4. Samsung NX30 Flash Replacement, Flash: passo 4, imagem 1 %32
    • If you are looking at the front of the camera with the lens facing you, look at the right side of the camera, press the flash button to pop up the flash head.
    Pergunte ao FixBot
    Comentar
  5. Samsung NX30 Flash Replacement: passo 5, imagem 1 %32 Samsung NX30 Flash Replacement: passo 5, imagem 2 %32
    • Once the flash head is up, unscrew the two black 4mm Phillips head screws located on either side of the flash bulb.
    Pergunte ao FixBot
    Comentar
  6. Samsung NX30 Flash Replacement: passo 6, imagem 1 %32
    • Once the screws have been removed, push the flash head back down.
    Pergunte ao FixBot
    Comentar
  7. Samsung NX30 Flash Replacement: passo 7, imagem 1 %32 Samsung NX30 Flash Replacement: passo 7, imagem 2 %32 Samsung NX30 Flash Replacement: passo 7, imagem 3 %32
    • After closing the flash head, pull the black flash head cover up and off of the flash head.
    Pergunte ao FixBot
    Comentar
  8. Samsung NX30 Flash Replacement: passo 8, imagem 1 %32 Samsung NX30 Flash Replacement: passo 8, imagem 2 %32
    • Once the flash cover has been removed, unscrew the two silver 3mm Phillips head screws located on the top of the flash head.
    • Do not touch the metal leads on either side of the flash, and avoid touching any metal. The capacitor may be charged and it will shock you.
    Pergunte ao FixBot
    Comentar
  9. Samsung NX30 Flash Replacement: passo 9, imagem 1 %32
    • Once the screws have been removed, pull the flash bulb out from the camera.
    • Then remove the flash from the camera by soldering the flash bulb off, using a soldering iron.
    • For tips on soldering, check out the Soldering Technique Guide.
    Pergunte ao FixBot
    Comentar
Conclusão
William
Membro desde: 02/03/16
191 Reputação
Autoria de 1 guia
Equipe
UW Tacoma, Team 1-4, Rose Winter 2016 Membro de UW Tacoma, Team 1-4, Rose Winter 2016
UWT-ROSE-W16S1G4
4 Membros
Autoria de 11 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 63
Ao todo: 1,452
