Ir para o conteúdo principal
Samsung Gear Fit Screen Replacement
O que você precisa
    1. Samsung Gear Fit Screen Replacement, Watch Band: passo 1, imagem 1 %32 Samsung Gear Fit Screen Replacement, Watch Band: passo 1, imagem 2 %32
      • Place your thumbs on the ends of the screen.
      • Push the watch outward while pulling the band away from the watch.
      Pergunte ao FixBot
      Comentar
    1. Samsung Gear Fit Screen Replacement, Screen: passo 2, imagem 1 %32
      • Heating the device with a hair dryer may warp the screen or damage the device. It it preferable to use an iOpener for this step.
      • For step-by-step instructions on using an iOpener, see the iOpener Instructions.
      • Use a hair dryer, heat gun, or an iOpener to heat the Gear Fit for 1-2 minutes until it is hot to the touch.
      Pergunte ao FixBot
      Comentar
    2. Samsung Gear Fit Screen Replacement: passo 3, imagem 1 %32 Samsung Gear Fit Screen Replacement: passo 3, imagem 2 %32 Samsung Gear Fit Screen Replacement: passo 3, imagem 3 %32
      • The screen is connected to the device by a ribbon cable on the left side with the power button facing you. Do not try to completely separate the screen from the device yet, and be careful.
      • Gently pry the screen loose using a plastic opening tool.
      • If the screen doesn't easily come loose, more heating may be required
      Pergunte ao FixBot
      Comentar
    3. Samsung Gear Fit Screen Replacement: passo 4, imagem 1 %32 Samsung Gear Fit Screen Replacement: passo 4, imagem 2 %32 Samsung Gear Fit Screen Replacement: passo 4, imagem 3 %32
      Ferramenta utilizada neste passo:
      • Using tweezers as a lever, pry the inner assembly out of the external casing.
      • This will be harder than removing the screen. Moderate force may be required.
      Pergunte ao FixBot
      Comentar
    4. Samsung Gear Fit Screen Replacement: passo 5, imagem 1 %32 Samsung Gear Fit Screen Replacement: passo 5, imagem 2 %32 Samsung Gear Fit Screen Replacement: passo 5, imagem 3 %32
      • Disconnect the ribbon cables connecting the screen to the motherboard by lifting their metal connectors up off of the board with tweezers.
      Pergunte ao FixBot
      Comentar
    5. Samsung Gear Fit Screen Replacement: passo 6, imagem 1 %32 Samsung Gear Fit Screen Replacement: passo 6, imagem 2 %32
      • Gently peel the screen assembly up and away from the device using tweezers.
      Pergunte ao FixBot
      Comentar
Conclusão
17 outras pessoas executaram este guia.
Nathan Powell
Membro desde: 04/24/14
1.584 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 11-49, Amido Spring 2014 Membro de Cal Poly, Team 11-49, Amido Spring 2014
CPSU-AMIDO-S14S11G49
4 Membros
Autoria de 4 guias
28Comentários do guia
Hi!
Thank you very much for this tuto. But wher can we acquire the screen ???
Thanks a lot.
AB
aaa - Responder Compartilhar
Where can you buy replacement screen?
Yele Olaniyi - Responder Compartilhar
I'm also finding it difficult to buy a replacement screen too. Has anyone discovered some. I thought this website was selling some not too long ago. Any more coming in?
Rochelle - Responder Compartilhar
Hi guys,
is it possible to detach the display unit from the protective plastic cover (I think it's not glass) ?
alexxtodorov - Responder Compartilhar
Does anyone know where to get the replacement screen?
MrGratts - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 35
Ao todo: 54,679
