Introdução
The fingerprint sensor scans your finger to unlock your device. This guide will come in handy if you are having difficulty unlocking your phone or getting it to read your fingerprint. Before you begin, check out our troubleshooting page to see if your issues are hardware problems.
If you remove the fingerprint sensor, the waterproof seal will break. If you reassemble your device without replacing the seals, your device will run normally, but will no longer have its waterproof capabilities.
O que você precisa
Before you begin, switch off your phone.
Apply a heated iOpener to a long edge of the phone to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes.
Press a suction cup onto the back cover.
Lift the back cover's bottom edge with your suction cup, opening a slight gap between the back cover and the frame.
Insert an opening pick in the gap you created and slide it to the bottom right corner.
Insert a second opening pick and slide it to the bottom left corner.
Insert a third opening pick to prevent the adhesive from resealing during the rest of the removal procedure.
Heat up the iOpener in the microwave for 30-60 seconds.
Place the iOpener on the back cover for 2-3 minutes to heat up the adhesive holding the fingerprint sensor.
Uma outra pessoa concluiu este guia.
