Ir para o conteúdo principal
Samsung Galaxy S5 Display Assembly Replacement
O que você precisa
Vídeo de Apresentação
  1. Samsung Galaxy S5 Display Assembly Replacement, Rear Case: passo 1, imagem 1 %32 Samsung Galaxy S5 Display Assembly Replacement, Rear Case: passo 1, imagem 2 %32 Samsung Galaxy S5 Display Assembly Replacement, Rear Case: passo 1, imagem 3 %32
    • Insert a fingernail or plastic opening tool into the divot to the left of the rear-facing camera.
    • Gently pry and twist the flexible rear cover off the back of the phone.
  2. Samsung Galaxy S5 Display Assembly Replacement, Battery: passo 2, imagem 1 %32 Samsung Galaxy S5 Display Assembly Replacement, Battery: passo 2, imagem 2 %32 Samsung Galaxy S5 Display Assembly Replacement, Battery: passo 2, imagem 3 %32
    • Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward.
    • Remove the battery away from the phone.
    The battery will need to be charged after it is placed in the phone. No one told me that and I bought a battery and thought it was bad. Keep the phone off and insert the charger. You will need to charge it for several hours before you can use the phone.
    Diane Schumacher - Responder
  3. Samsung Galaxy S5 Display Assembly Replacement, microSD Card: passo 3, imagem 1 %32 Samsung Galaxy S5 Display Assembly Replacement, microSD Card: passo 3, imagem 2 %32
    • Using a fingertip, pull the microSD card straight down out of its slot.
    • Remove the microSD card from the phone.
    I found removing the SIM/SD card with my fingertip a little difficult – not enough friction. So I used a 'rubber' (in US English it's called a pencil eraser or just simply, an eraser.
    Simple, cheap (zero) and effective! :)
    Cheers.
    John
    johnsg0053 - Responder
  4. Samsung Galaxy S5 Display Assembly Replacement, SIM Card: passo 4, imagem 1 %32
    • Repeat the above procedure to remove the SIM card.
    Actually this isn’t as easy as it appears in the photo and instructions, since the SIM card does not have a notch that you can use to pull it out. In my experience I’ve found that the best way to remove the SIM card is by pressing down somewhat hard on the SIM card, and then push-pulling it outward.
    OmniWeb Technical Education - Responder
  5. Samsung Galaxy S5 Display Assembly Replacement, Display Assembly: passo 5, imagem 1 %32 Samsung Galaxy S5 Display Assembly Replacement, Display Assembly: passo 5, imagem 2 %32 Samsung Galaxy S5 Display Assembly Replacement, Display Assembly: passo 5, imagem 3 %32
    • Use a plastic opening tool to pry up the plastic midframe connector panel.
    • Remove the connector panel with a pair of tweezers.
    • There should be enough adhesive to readhere the panel upon reassembly, otherwise use a small amount of double-stick tape.
    In my experience I have always removed this Home button protector panel with ONLY a plastic opening tool, and I have never found adhesive beneath it.
  6. Samsung Galaxy S5 Display Assembly Replacement: passo 6, imagem 1 %32 Samsung Galaxy S5 Display Assembly Replacement: passo 6, imagem 2 %32
    • Use the sharp tip of a spudger to pry the home button cable connector straight up off its socket.
  7. Samsung Galaxy S5 Display Assembly Replacement: passo 7, imagem 1 %32 Samsung Galaxy S5 Display Assembly Replacement: passo 7, imagem 2 %32
    • In the following steps you will be using an iOpener to warm the adhesive affixing the display assembly to the rest of the phone. This will allow for a safer, easier screen removal. For proper iOpener use, follow our iOpener heating guide, make sure to pay attention to all warnings.
    • Place a heated iOpener on the left side of the phone for at least 90 seconds.
    • Reheat the iOpener and place it on the right half of the phone.
    good location for a timer, I am taking my phone apart
    andrew beals - Responder
    ¿se puede hacer con la pistola de calor?
    Diego Alomoto - Responder
    Si, puedes utilizar la pistola de calor también, pero ten cuidado ;-)
    Sandra Hiller -
    Otra opción es usar una “placa calefactora” que, según yo, es la opción mas “profesional” ya que con ella se puede limitar la temperatura, para que no se malogre la pantalla táctil (la “digitizador” detŕas del vídrio).
    Another option is to use a “hot plate” which, according to me, is the more “professional” option since with it you can limit the temperature, so that the touchscreen doesn’t get ruined (the “digitizer” behind the glass).
    A hairdryer on low not being used statically is also an easy option. Or if your a caveman or low tech, and all you have is a single baby sock and metal bb’s or little rocks, as long as they’re not silica rocks, put them in the baby sock, at the edge of your cave campfire to warm them and thats all you need. -retired aviation engineer
    crabbysam - Responder
  8. Samsung Galaxy S5 Display Assembly Replacement: passo 8, imagem 1 %32 Samsung Galaxy S5 Display Assembly Replacement: passo 8, imagem 2 %32
    • In the following steps you will be using an opening pick to separate the adhesive securing the front panel glass. Only pry where directed. If you experience resistance, stop sliding the opening pick and reapply heat.
    • Insert the edge of an opening pick underneath the bottom right side of the front glass.
    I hope this helps others:
    my screen was STRONGLY glued to the midframe, it was impossible to remove it without breaking it, be very careful with the copper adhesive in the midframe!!!
    I can't even understand how this guide doesn't mention it properly!
    Pedro - Responder
    Yeah, the real trick with these types of screens is to measure (or just “have a feel for”) an adequate temperature with the heat pad (e.g. iOpener), or heat gun, or hot plate. First you have to heat up the screen just enough so that you can “break into” one side without breaking the bezel or the glass, and then verrrry carefully and verrrrry gradually insert plastic opening picks (or even playing cards) as you make progress around the exterior border of the phone. Whenever I do this, I always insert 5-6 objects (again, plastic picks or playing cards) before I fully remove the digitizer-glass assembly, which typically ends up as follows as I move around the exterior border: one pick at each of the four corners and one pick on each of the two sides. WARNING: DO NOT INSERT ANY OBJECT BENEATH THE GLASS MORE THAN A FEW MILLIMETRES FROM THE EXTERIOR BORDER.
    Thanks for the info guys! :-)
    Tony - Responder
    Wow seriously 100% ur going to break the LCD if this is the first time opening the phone this is why android is built disposable it now costs 60$ to fix a stupid 10$ part this fix is definitely not worth it
    android=disposable
    apple=a better way of life
    I will never attempt to fix another android again
    taylor britton - Responder
  9. Samsung Galaxy S5 Display Assembly Replacement: passo 9, imagem 1 %32 Samsung Galaxy S5 Display Assembly Replacement: passo 9, imagem 2 %32 Samsung Galaxy S5 Display Assembly Replacement: passo 9, imagem 3 %32
    • Slide the opening pick up along the right side of the display.
    This is not as easy as they make it seem in this guide. The real trick with these types of touchscreens is to properly measure (or just “have a feel for”) an adequate temperature with the heat pad (e.g. iOpener), or heat gun, or hot plate, that you use to heat the adhesive beneath the glass exterior of the digitizer-glass assembly. First you have to heat up the screen just enough so that you can “break into” one side without breaking the bezel or the glass, and then verrrry carefully and verrrrry gradually insert plastic opening picks (or even playing cards) as you make progress around the exterior border of the phone. Whenever I do this, I always insert 5-6 objects (again, plastic picks or playing cards) before I fully remove the digitizer-glass assembly, which typically ends up as follows as I move around the exterior border: one pick at each of the four corners and one pick on each of the two sides. WARNING: DO NOT INSERT ANY OBJECT BENEATH THE GLASS MORE THAN A FEW MILLIMETRES FROM THE EXTERIOR BORDER.
  10. Samsung Galaxy S5 Display Assembly Replacement: passo 10, imagem 1 %32 Samsung Galaxy S5 Display Assembly Replacement: passo 10, imagem 2 %32 Samsung Galaxy S5 Display Assembly Replacement: passo 10, imagem 3 %32
    • Carefully slide the pick around the corner, stopping before the speaker grille at the top of the phone.
    Be sure not to nick and tear the capacitive touch chip interface that meets the LCD screen here! I caught it and didn't even feel the resistance. :-(
    Play It Loud Computer Services - Responder
  11. Samsung Galaxy S5 Display Assembly Replacement: passo 11, imagem 1 %32 Samsung Galaxy S5 Display Assembly Replacement: passo 11, imagem 2 %32 Samsung Galaxy S5 Display Assembly Replacement: passo 11, imagem 3 %32
    • The adhesive securing the top of the phone is only a narrow strip above the earpiece speaker. Slide the pick along the top of the speaker to avoid damaging internal components.
    • Slide the opening pick across the top of the phone, being very careful not to insert the pick too deeply.
    I have been extra careful, and it did not prevent me to sever the flat cable in the upper left corner. The cable is very close and you should take extreme caution.
    Neocray - Responder
    I accidentally sliced the flex cable and now my Digitizer refuses to work….LCD is still functional.
    Take heed lol. I found out the hard
    Blank - Responder
  12. Samsung Galaxy S5 Display Assembly Replacement: passo 12, imagem 1 %32 Samsung Galaxy S5 Display Assembly Replacement: passo 12, imagem 2 %32 Samsung Galaxy S5 Display Assembly Replacement: passo 12, imagem 3 %32
    • Carefully slide the pick around the upper left corner.
    • If you encounter any resistance from cooling adhesive, reapply a heated iOpener to the left side of the phone.
  13. Samsung Galaxy S5 Display Assembly Replacement: passo 13, imagem 1 %32 Samsung Galaxy S5 Display Assembly Replacement: passo 13, imagem 2 %32 Samsung Galaxy S5 Display Assembly Replacement: passo 13, imagem 3 %32
    • Slide the opening pick down along the left half of the phone stopping at the lower left corner.
  14. Samsung Galaxy S5 Display Assembly Replacement: passo 14, imagem 1 %32 Samsung Galaxy S5 Display Assembly Replacement: passo 14, imagem 2 %32
    • Slide the opening pick all the way to the bottom left corner of the phone, making sure it is securely placed.
    • In the following step you will be placing an iOpener over the home button end of the phone, you won't want your opening pick to slip out.
  15. Samsung Galaxy S5 Display Assembly Replacement: passo 15, imagem 1 %32
    • Place a reheated iOpener over the bottom portion of the display assembly.
    • There are delicate components in this portion of the phone, you want to ensure the adhesive is warm and easy to loosen to protect the phone.
  16. Samsung Galaxy S5 Display Assembly Replacement: passo 16, imagem 1 %32 Samsung Galaxy S5 Display Assembly Replacement: passo 16, imagem 2 %32 Samsung Galaxy S5 Display Assembly Replacement: passo 16, imagem 3 %32
    • The bottom end of the phone contains the soft button and home button ribbon cables. If you insert the opening pick too far into the phone you risk cutting these cables.
    • Slide the very end of the opening pick across the bottom edge of the display to separate the last of the remaining adhesive.
    How do I avoid damage? I tried this and now have to get a new screen, LED, and digitizer since the grey part under the glass snapped and cracked in many areas. I had to discard it and order a replacement to fix the phone.
    cbressijr - Responder
  17. Samsung Galaxy S5 Display Assembly Replacement: passo 17, imagem 1 %32 Samsung Galaxy S5 Display Assembly Replacement: passo 17, imagem 2 %32
    • Twist the opening pick to detach the glass from the phone.
    • If the front panel does not detach easily, it may require additional adhesive cutting.
    Be aware that there is adhesive on the inner parts of the screen. Plan on replacing this screen and digitizer as well.
    AB Computer Services - Responder
  18. Samsung Galaxy S5 Display Assembly Replacement: passo 18, imagem 1 %32 Samsung Galaxy S5 Display Assembly Replacement: passo 18, imagem 2 %32
    • If the front panel is not easily freed, the adhesive on the soft button cable may need to be separated.
    • These cables are thin and easily damaged, therefore be certain you are only peeling them off the display assembly and not lacerating them.
    • Insert an opening pick under the soft button icons on the display and pry the button cables down off the inside of the front panel.
    Accidentally cut one of the side buttons. It wouldn't come out, the screen was badly cracked.
    Nickoakz - Responder
    My digitizer was glued to the chasis, the glass came up separately and the digitizer broke when I tried to pry it up.
    ken - Responder
    That’s actually probably because you might not have heated the sides of the screen (where the adhesive is located) enough before prying up on the exterior border of the glass part. It’s very difficult to know the tolerance limits of such devices if you’ve never seen them apart before, and as such one can easily get confused between where the glass ends and the digitizer begins. On my first smartphone repair I broke a digitizer, so I know how it feels.
  19. Samsung Galaxy S5 Display Assembly Replacement: passo 19, imagem 1 %32 Samsung Galaxy S5 Display Assembly Replacement: passo 19, imagem 2 %32
    • Slightly lift, but do not remove, the home button end of display assembly.
    • Do not remove the front panel entirely. It is still attached by a connector.
    • If you are reusing the home button flex cable, be careful not to sever the cable from the home button. Adhesive can cause the cable to rip apart from the home button. While the home button will still work, the fingerprint scanner will not.
    The display assembly I purchased from ifixit.com included a new home button with a new flex cable. If you have the same, I'd recommend removing the home button in this step.
    pdub01 - Responder
    Same here. My home-button flex cable extended under the main board rear cover plate, and would have required removing screws to extract. So I left the original home button installed, and removed the one that came with the new assembly.
    The ‘reverse order’ step are misleading. It is not trivial to reconnect the main screen flex cable to the main assembly — lots of trial and error to get it snugly plugged into the receiving connector. That part is glossed over. (Dissassembly is trivial. Reassembly is hard.)
    After putting the screen and connectors on, I learned that there’s some plastic edging on the BACK. I had to remove the screen since it effectively wraps the home-button key. The new screen cracked. Great.
    Peter Nicoll -
    Sansumg S5 is the stupiest design (for repair) ever.
    I have fixed s2,s3,s4, note, note 2 and note 3
    All of them, you can get into the logic board from the back without touching the screen assembly.
    With the S5, just a simple problem could cost you buying a new lcd assembly.
    You must remove the lcd in order to remove the screws for the logic board cover.
    I purchased a cracked lcd S5, so I can replace it and sell it. My mistake was I did not did a research on the tear down (thinking it should the same as previous S model.
    To make story short, lucky for me, I did a dry test of the entire phone, before glueing on the new lcd assembly.
    Because the front camera lens was damaged, cost $5.
    If I glued the lcd, it would be 50/50 chance that I would crack the new screen.
    So any repair that you need to do on the S5, you will have to consider the risk of breaking the LCD.
    I hope Samsung change the design on the S6. Which I doubt it. Because the higher cost of repair means people won't fix them = more new sells
    idevice Recycle - Responder
    How can I find out if I messed my phone up . the person who glued the screen on didn't glue it on right , so I tried to take off the screen and I got it off but now that I try to put it back on the screen is black .
    cholitaesh21 -
    I know this reply is a bit late, over 2 years late, but I just wanted to add to idevice Recycle that the way "they" designed this phone is exactly as you described, to make it wayyyy more difficult to fix even the most simplest thing on this phone. Inverting the motherboard, designed exactly the opposite way of the S4 (as you described), from their standpoint of view, as you'd have to admit, was a brilliant idea on "they're" part.
    I've torn apart and fixed many cell/smart phones in my days thus far, but mostly iphones by far. A friend passed
    me one of these phones this past week. I've never messed with one before so you already know, even though I
    have much knowledge about them, this site was the first I visited about this phone. Needless to say, go figure.
    They did a really great job though making this phone one of the most difficult phones to do any type of repair
    on. Adhesive sucks. But eh, all is well with a bit of time and patience. Had to replace rear camera and middle
    bezel frame. Time to off it....
    you_mad.lil_fella -
    This guide may have been written for a different revision but the SM-G900F that I just repaired had glue sticking the entire of the rear of the screen to the chassis making it very difficult to remove. Had to use a spudger and push it down the inside of the phone separating the copper film from the chassis to free it up. Would be easy to damage the home button cable but I was ok.
    Adam - Responder
    I had the same thing happen just now. I was working on a G900A. A real PITA!
    mcr4u2 -
    Is there a need to put adhesive after removing the screen?? If so, do you have an adhesive recommended...
    garrykufa2000 - Responder
    Should be. i recommend using 3m strip double sided adhesive
    leiki42 -
    I had the same issue as idevice recycle. The model S5 that I was working on had a huge amount of glue on the back of the lcd which I wasn't aware of - this caused me to crack the glass which then literally broke the lcd in half (costing me £120 for a new screen!!!)
    I've repaired all manner of Samsung products over the years and I've never had any issues with any model apart from this one. My advice to anyone doing this repair is once you have managed to unstick the screen from the frame, before attempting to remove it, apply a bit of heat (but not too much, you don't want to damage anything) to the back of the phone where the battery normally sits. This is where all the glue on the back of the lcd is located which sticks the lcd to the frame of the phone - I wish I knew of this before trying to remove the screen!
    Clems - Responder
    The guide needs to mention that the LCD is firmly glued.. Mine was bust anyway, but Step 19 is not fit for purpose.
    Dave - Responder
    So this really blows. I needed to swap the logic board from a phone with a cracked screen to one with a good screen. Yeah that’s not happening. I now have two cracked screens… Thanks Samsung! The difficulty on this should be way higher. As others have said, the screen is glued on the underside over a large portion where the copper foil is. It’s not coming up easily or in one piece.
    Jeremy Buseman - Responder
    If you want to make the reassembly easier, be careful to not separate the Home button assembly, from the glass. Instead, just carefully pry away the soft button adhesive connectors.
  20. Samsung Galaxy S5 Display Assembly Replacement: passo 20, imagem 1 %32 Samsung Galaxy S5 Display Assembly Replacement: passo 20, imagem 2 %32 Samsung Galaxy S5 Display Assembly Replacement: passo 20, imagem 3 %32
    • Use the sharp tip of a spudger to lift the front panel assembly cable connector straight up off its socket on the motherboard.
    • Safely remove the front panel assembly from phone.
    • If your replacement display did not come with a home button, follow our Home Button Assembly guide to transfer your old button over to the new display, or install a new button.
    Absolutely wonderful! Worked like a charm. This is the easiest replacement I have seen so far on an Android. :)
    Paul Frutiger - Responder
    This was all a breeze until I removed the screen and the LCD and digitizer crumpled on me now I have to replace the whole thing not just the charge port which was the initial issue… Great guide though and thanks it helped. Minus the panic attacked when all the parts started to crack and break as I removed the glass and now digitizer or LCD stayed safe for replacement.
    Be VERY careful of the flex ribbon on the LCD …it'll break with the slightest twitch…one of mine ripped totally in half
    Blank - Responder
    please i need number lcd samsunggalaxy s 5 it is g 900 a or what?
    fady awad - Responder
    The difficulty of changing the S5's display is enormous. Not only is it glued around the edges, it's also glued strongly to the midframe. If you ignore this, damage is inevitable. The digitizer flex cable is also very easy to kill. Glue sucks. When assembling the display, the edge bonding is not enough; you need special double-sided adhesive tape that is stuck to the midframe so that the display does not fall out again so quickly. Before doing this, you have to thoroughly remove the old adhesive on the edge. I have successfully performed this procedure once but would never do it again.
    Karl Napf - Responder
Conclusão
535 outras pessoas executaram este guia.
Sam Goldheart
Membro desde: 10/18/12
465.854 Reputação
Autoria de 538 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 17.198 guias
36 comentários
Be aware that the LCD is glued not just at the edges, but also in the middle (the orange areas in the photos for Step 20. These can adhere strongly enough to cause the LCD to crack. Don't ask how I know that.
Nathan Hillery - Responder
I cracked it this way, so yeah. Any way to get the glue fluetly enough to get the LCD off the rest of the Phone? (the LCD and digitalizer is cracked anyway)
Mick Trompke -
Onfortunately I read this to late. Many thanks anyway for confirming I'm not the only one ;)
tkuilman1 -
Been there man. Had my Samsung Galaxy S5 Active pull one of those numbers. not a fun time.
Cameron Dawson -
Just found out about that, during my first time. Thanks for the tip.
Brandon Blair -
Am I missing something?
How does it get re glued when you reverse the process? Doesn't it need to be re glued so water doesn't get into the hardware past the screen?
That would be my concern, the phone not being waterproof after the repairs are completed.
Thanks for your insight. Guide is done very well.
Bogdan.
Bogdan Georgescu - Responder
I agree Bogdan Georgescu, the step of adding a new screen is not covered in these instructions but would be very helpful to know if anyone has experience? The instructions are wonderful to help you remove a screen, but the process of replacing is lacking for me. Has anyone had success replacing a screen that primarily has had surface damage? (I pay a monthly insurance fee on my galaxy s5 phone. But in addition, if I wanted to replace it, it will cost another $200 to get a replacement (refurbished - someone else's junk?) phone. I'd rather chance starting with replacing my screen myself, with the help from this online community if possible? Thank you!!! Karen
Karen -
They don't use glue, they use double sided adhesive that is not easy to find. 3M double sided tape works well but I have had screens come up when using the 3M adhesive. So yes you need to apply adhesive before install of new screen to keep it water resistant. The phone is and never was waterproof just resistant and I recommend using the best double sided tape you can get as you will fudge up the already adhered tape.
Jason Oestrike -
As mentioned above, the screens are held down by double sided tape, usually made by the 3M company. But most other good quality tape can do the same. The proper tapes are cut perfectly to fit all the little adge bits of the casing-to-screen, and that's all that makes it waterproof.
A thing to remember is, most people loose the charger cover anyway, so worrying about a perfect screen seal from water doesn't matter then I guess as water will just flow in anyway.
The screen isnt really waterproof, its just water resistant, so it's okay for the odd splash, but drop it in a bucket, and it's probably ruined :-( unless the bucket is empty of course ;-) When I refit a screen, i put a 5mm strip of my own tape down the centre (it MUST be the thinnest tape possible!!) and that helps keep the screens in place, but that idea varies from one phone model to another.
philpeacock -
I replaced my midframe, but I cut the cables to the back and menu buttons. I also ripped some of the foil on the back of my screen, but that didn't seem to hurt anything.
Jonathan Good - Responder
Hey guys, I also cracked my screen, unfortunately. Not the glass as is usually the case but really the screen to the point it doesn't display anything.
However after digging around the Internet I found out that in order to replace your screen you need the service kit along with the new display unit.
The partnumber is GH81-12060A.
How one would remove the old adhesive is still a mystery as I'm not convinced a hair blower will do this time.
Cheers, Ronald R.
Ronald Roeleveld - Responder
I did use a hair dryer, you just need to keep it on it a long time.
hijadelamadre -
For reassembly, https://www.youtube.com/watch?v=gEgOsFPX....
I found it useful to have a reference for adhesive application. It wasn't complicated, but by far it was the most time consuming part of the repair.
pdub01 - Responder
My glass separated from the digitizer, but it was no biggie. Just go slow with the ribbon cables and it works perfectly. Don't forget to buy new tape, too.
aaronboyle - Responder
Thanks a bunch Sam! Really useful, especially when you run a phone repair shop ( http://www.iphonerepairscolchester.co.uk... ) ;)
Matt Harwood - Responder
OK , for all those people that want to know about the adhesive once putting the new screen on. There is adhesive also on the new screen, protected by a blue plastic peel cover. When you're ready to place the screen back and you've connected it to the motherboard peel and cut the blue plastic glue cover on the new screen so you can slowly place the screen and peel the blue glue protector slowly (keep in mind that in my case the plastic was blue but that might not be the case for everyone).
Sebastian Soares - Responder
@Bogdan Georgescu and others asking about reassembly of the phone and what, if any adhesive is needed to adhere the new display.
Step 5 has a note listed as follows:
"There should be enough adhesive to readhere the panel upon reassembly, otherwise use a small amount of double-stick tape"
This is a very extensive guide. I have a job soon to replace the display and digitizer and was doing a bit of research ahead of time. I can't wait to put my new iFixit toolset to work!
-Dave from Ohio
David Scurlock - Responder
I did it last night, totally ripped off my phone. only survival parts are the cameras and battery. I should start from top of the screen, disconnect cables from top.
James yin - Responder
Thank you SOOO MUCH for this, you saved my ass! I just got this phone back in September and shattered the LCD part this past weekend. Because of your guide I have my phone back in service again! Now I just need to take it apart once more to reglue or tape it and maybe get a little sturdier case. Again, THANK YOU!!!
Laura Buske - Responder
Using just a medium stiffness guitar pick and some boiled water in a bag wrapped in cloth I was able to do this tutorial. Thanks for the run through! But you don't need to buy the tools listed, such as the iOpener, spudger , or "opening pick".
Albert Onestone - Responder
Glass only? My phone has a cracked screen - a car ran over it! I'd like to try replacing just the glass, not the digitizer, to minimize my investment in case the damage is bad. Would I follow the same steps, but somehow take the screen off the digitizer?
Karen Metschuleit - Responder
you cant replace the glass alone you need to replace both the screen and digitizer
Brandon Pierrard -
Heat guns are much more efficient as there is a considerable amount of glue throughout the middle of the phone. Would recommend using a heat gun over the iOpener.
Harry Rowse - Responder
Thank you for the advice. will definitely do this. i own a heatgun, not an IOpener, so less hardware to buy anyways.
Cameron Dawson -
Well it definitely worked but unfortunately it came off in quite a few pieces. the front glass remained in tact, all the ribbons and button bands are in tact, but the LCD and Backlight are thuroughly thrashed.
I think step one of this guide should definitely be changed to "Be Jesus Christ" since it seems like the only way to get that pesky digitizer and LCD up in one piece is by an act of pure magic.
Cameron Dawson -
Hair Dryer, Safety Razor & a small slotted screw driver!
Greg Hopper - Responder
Thanks. These work really well.
Louis -
fantastic, your graphics are great.
vanlog vanlog - Responder
can you buy the screen and display digitizer separate for a galaxy s5 g900 and if so where ?
Shan Foster - Responder
It is possible to get them seperate, but the process for fixing them together is complicated. The touch panel is just the thinnest glass layer, and very very cheap from all sorts of places (I don't want to advertise any company names). But to make that glass stick to the LCD panel, requires special UV glue (a very thin glue that only becomes sticky when UV light is applied to it in the right amount) for the right length of time).
It's practically impossible to split your original glass from the LCD panel though - the UV glue is a one way thing, the LCD panel is so sensitive it will 99% break, and the touch glass is also about 1mm thick and very weak.
For that reason, most people just buy a complete screen, and make it into a 10 minute job to refit it.
philpeacock -
Please make sure that you have re-fed the home button cable through the chassis before you place and seal the new LCD + Digitizer unit onto the phone. If you are replacing the chassis too please beware and DO NOT forget to re-screw all 10 screws that fix the chassis to the motherboard before you place and seal the new LCD + Digitizer Unit. You don't want to know what made me post these two essential things you might forget. Let's say I'm suddenly very experienced at opening this phone ;)
Gwylan Scheeren - Responder
While Step 18 (soft button adhesives) wasn’t an issue with my phone, please note the following:
- The display adhesive is actually thin black rubber running along the entire perimeter of the phone. It is important to separate the adhesive from the display and not the phone.. or you’ll have a terrible time reattaching/replacing the display.
- The display also sticks to the phone in the middle (no rubber adhesive, just sticky). No step accounts for this, so be extra careful/slow pulling off the display. With enough clearance, you may need to insert a plastic prod between the display & middle of phone and gently help unstick the two.
- Up where the speaker, camera, & light-sensor are, the adhesive gets even thinner as it runs in-between said components. Be extremely careful/slow pulling it off the display. It may even separate from the phone too, but you can gently place it back along the perimeter as long as you ensured the rest of the adhesive remained stuck to the phone.
1/2
louisloria - Responder
- There is a “Step 21” if you intend to remove the home button & finger-print scanner. The home button also uses thin black rubber adhesive to attach it to the display. The finger-print scanner ribbon only sticks to display (no rubber adhesive). Again, be extra careful/slow pulling these off the display (with the plastic pick) while keeping the rubber adhesive attached to just the button.
- I used a hair dryer every now & then to loosen up the adhesive as well as to make it tacky during reattachment/replacement of the display.
2/2
I had a S5 with a “display flickering green on low brightness” defect.
I used a heat gun to heat up the display, this way it was really easy to separate the display from the phone, even the middle glued part. Unfortunately, I think I applied too much force and broke the digitizer (not visibly, but no input was recognized afterwards), so be super careful pulling up the display, using the plastic openers as much as possible.
Make sure to remove the speaker grill and put it on the new display before reinstalling!
The display was then replaced with an original Samsung display (coming in a service pack, part AMS510CV01 REV 2.0), it came with preapplied glue and homebutton, worked flawless and the flickering on low brightness was gone.
After reinstalling, I reheated the display with the heat gun and applied mild pressure to all edges for 15 minutes, otherwise the display would not attach properly to the phone.
Moritz Horstmann - Responder
Does anyone know if you can swap the screen of a at&t s5 with a Verizon one?
The invader 2 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 74
Últimos 30 dias: 240
Duração total: 750,389
