Introdução
Use this guide to replace the USB-C port and charging board in your Samsung Galaxy S22+.
Before you begin, refer to the Samsung Self-Repair document for safety information.
Before disassembling your device, completely discharge the battery. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Note: Retaining water resistance after the repair will depend on how well you reapply the adhesive, but your device will lose its IP (Ingress Protection) rating.
O que você precisa
Insert a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the bottom edge of the phone.
Press the SIM eject tool into the SIM card tray hole to eject the SIM card tray.
Remove the SIM card tray.
Prepare an iOpener and apply it to the bottom edge of the back cover for three minutes to loosen the adhesive underneath.
Secure a suction handle to the bottom edge of the back cover, as close to the edge as possible.
Lift the back cover with the suction handle to create a small gap between the back cover and the frame.
Insert an opening pick into the gap you created.
Remove the suction handle.
Slide the opening pick along the bottom edge to slice the adhesive.
Leave the opening pick inserted near the bottom left corner to prevent the adhesive from resealing.
Apply the heated iOpener to the left edge of the phone for 3 minutes to soften the adhesive.
Reheat your iOpener for 30 seconds if necessary.
Insert a second opening pick into the gap created near the bottom left corner.
Slide the opening pick along the left edge to slice the adhesive.
Leave the opening pick inserted near the top left corner to prevent the adhesive from resealing.
Remove the back cover.
This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
If you're using Samsung custom-cut adhesives, follow this guide.
If you're using double-sided tape, follow this guide.
Use the pointed end of your spudger to pry up and disconnect the charging coil's press connector from the motherboard.
Use the pointed end of your spudger to pry up and disconnect the NFC antenna cable from the motherboard.
If you're using the Samsung Self Repair Kit, take a moment to identify your screws and label them accordingly:
Label the bag with the most screws and the colored bag #3428.
Label the clear bag with two screws #3229.
Use your Phillips screwdriver to remove the six 3.5 mm screws securing the charging coil.
Use your Phillips screwdriver to remove the seven 3.5 mm screws securing the loudspeaker.
Insert your spudger in between the left edge of the loudspeaker and the frame.
Pry up to disconnect the clips securing the loudspeaker.
Gently remove the charging coil & NFC antenna assembly.
Use your spudger to pry up and disconnect the battery's press connector.
Use your spudger to pry up and disconnect the primary interconnect cable from the motherboard.
Use your spudger to pry up and disconnect the secondary interconnect cable from the motherboard.
Use your Phillips screwdriver to remove the three 3.4 mm screws securing the charging board.
To reassemble your device, follow the instructions in reverse order and perform the opposite actions, e.g., "reattach" instead of "removing." Skip steps that use heating and prying, and pay close attention to the 📌 bullets as you work through the steps.
After you've completed the repair, download the Samsung Members App from the Galaxy Store or the Play Store, and Samsung Self-Repair document (beginning page 10) to make sure your device is fully functional.
4 outras pessoas executaram este guia.
