Ir para o conteúdo principal
Samsung Galaxy S21 Ultra Loudspeaker Replacement
O que você precisa
  1. Samsung Galaxy S21 Ultra Loudspeaker Replacement, Heat the back cover: passo 1, imagem 1 %32
    • Unplug and power off your phone before you begin.
    • Prepare an iOpener and apply it to the back cover for at least three minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Samsung Galaxy S21 Ultra Loudspeaker Replacement, Insert an opening pick: passo 2, imagem 1 %32 Samsung Galaxy S21 Ultra Loudspeaker Replacement, Insert an opening pick: passo 2, imagem 2 %32 Samsung Galaxy S21 Ultra Loudspeaker Replacement, Insert an opening pick: passo 2, imagem 3 %32
    • Secure a suction handle to the bottom edge of the back cover, as close to the edge as possible.
    • If the back cover is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken cover.
    • Lift the back cover with the suction handle to create a small gap between the back cover and the frame.
    • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap you created.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  3. Samsung Galaxy S21 Ultra Loudspeaker Replacement, Slice the adhesive: passo 3, imagem 1 %32 Samsung Galaxy S21 Ultra Loudspeaker Replacement, Slice the adhesive: passo 3, imagem 2 %32
    • Insert a second opening pick at the bottom edge of your phone.
    • Slide the opening pick to the bottom right corner to slice the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  4. Samsung Galaxy S21 Ultra Loudspeaker Replacement: passo 4, imagem 1 %32 Samsung Galaxy S21 Ultra Loudspeaker Replacement: passo 4, imagem 2 %32 Samsung Galaxy S21 Ultra Loudspeaker Replacement: passo 4, imagem 3 %32
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for two to three minutes to reheat it.
    • Insert a third opening pick at the bottom right corner of your phone.
    • Slide the opening pick along the right edge of your phone to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  5. Samsung Galaxy S21 Ultra Loudspeaker Replacement: passo 5, imagem 1 %32 Samsung Galaxy S21 Ultra Loudspeaker Replacement: passo 5, imagem 2 %32 Samsung Galaxy S21 Ultra Loudspeaker Replacement: passo 5, imagem 3 %32
    • When you slice near the camera assembly, insert only the tip of the opening pick (~ 4-5 mm) to avoid damaging or smearing the camera.
    • Insert a fourth opening pick underneath the top right corner of your phone.
    • Slide the opening pick along the top edge to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  6. Samsung Galaxy S21 Ultra Loudspeaker Replacement: passo 6, imagem 1 %32 Samsung Galaxy S21 Ultra Loudspeaker Replacement: passo 6, imagem 2 %32 Samsung Galaxy S21 Ultra Loudspeaker Replacement: passo 6, imagem 3 %32
    • Insert a fifth opening pick underneath the top left corner.
    • Slide the opening pick along the left edge of the back cover to slice the remaining adhesive.
    • When you slice near the power button, insert only the tip of the opening pick (~ 3-4 mm) to avoid damaging the power and volume button flex cable.
  7. Samsung Galaxy S21 Ultra Loudspeaker Replacement, Remove the back cover: passo 7, imagem 1 %32 Samsung Galaxy S21 Ultra Loudspeaker Replacement, Remove the back cover: passo 7, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Remove the back cover.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers.
    • Use some high concentration (over 90%) isopropyl alcohol to wipe away any adhesive residue.
    • If you're using Samsung custom-cut adhesives, follow this guide.
    • If you're using double-sided tape, follow this guide.
  8. Samsung Galaxy S21 Ultra Loudspeaker Replacement, Slice the adhesive: passo 8, imagem 1 %32 Samsung Galaxy S21 Ultra Loudspeaker Replacement, Slice the adhesive: passo 8, imagem 2 %32
    • Insert an opening pick underneath the left bottom end of the NFC antenna and charging coil assembly.
    • Carefully slide the opening pick along the bottom left edge of the assembly to separate it from the battery.
  9. Samsung Galaxy S21 Ultra Loudspeaker Replacement: passo 9, imagem 1 %32 Samsung Galaxy S21 Ultra Loudspeaker Replacement: passo 9, imagem 2 %32 Samsung Galaxy S21 Ultra Loudspeaker Replacement: passo 9, imagem 3 %32
    • Insert an opening pick underneath the bottom end of the NFC antenna and charging coil assembly.
    • Carefully slide the opening pick along the bottom of the assembly to separate it from the loudspeaker.
  10. Samsung Galaxy S21 Ultra Loudspeaker Replacement, Disconnect the charging coil: passo 10, imagem 1 %32 Samsung Galaxy S21 Ultra Loudspeaker Replacement, Disconnect the charging coil: passo 10, imagem 2 %32
    • Use a spudger to disconnect the charging coil by prying the connector straight up from its socket.
  11. Samsung Galaxy S21 Ultra Loudspeaker Replacement, Disconnect the NFC antenna: passo 11, imagem 1 %32 Samsung Galaxy S21 Ultra Loudspeaker Replacement, Disconnect the NFC antenna: passo 11, imagem 2 %32
    • Use a spudger to disconnect the NFC antenna by prying the connector straight up from its socket.
  12. Samsung Galaxy S21 Ultra Loudspeaker Replacement, Unfasten the NFC antenna & charging coil assembly screws: passo 12, imagem 1 %32
    • Use a Phillips screwdriver to remove the five 3.9 mm-long screws securing the NFC antenna and charging coil assembly.
  13. Samsung Galaxy S21 Ultra Loudspeaker Replacement, Remove the NFC antenna & charging coil assembly: passo 13, imagem 1 %32 Samsung Galaxy S21 Ultra Loudspeaker Replacement, Remove the NFC antenna & charging coil assembly: passo 13, imagem 2 %32 Samsung Galaxy S21 Ultra Loudspeaker Replacement, Remove the NFC antenna & charging coil assembly: passo 13, imagem 3 %32
    Comprar
    • Use a pair of tweezers or your fingers to carefully remove the NFC antenna and charging coil assembly.
  14. Samsung Galaxy S21 Ultra Loudspeaker Replacement, Disconnect the battery cable: passo 14, imagem 1 %32 Samsung Galaxy S21 Ultra Loudspeaker Replacement, Disconnect the battery cable: passo 14, imagem 2 %32
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
  15. Samsung Galaxy S21 Ultra Loudspeaker Replacement, Unfasten the loudspeaker assembly screws: passo 15, imagem 1 %32
    • Use a Phillips screwdriver to remove the four 3.9 mm-long screws securing the loudspeaker assembly.
  16. Samsung Galaxy S21 Ultra Loudspeaker Replacement, Pry up the loudspeaker assembly: passo 16, imagem 1 %32 Samsung Galaxy S21 Ultra Loudspeaker Replacement, Pry up the loudspeaker assembly: passo 16, imagem 2 %32
    • Insert a spudger into the gap between the top edge of the loudspeaker assembly and the midframe.
    • Use your spudger to pry up the loudspeaker assembly by tilting it downwards.
  17. Samsung Galaxy S21 Ultra Loudspeaker Replacement, Remove the loudspeaker assembly: passo 17, imagem 1 %32 Samsung Galaxy S21 Ultra Loudspeaker Replacement, Remove the loudspeaker assembly: passo 17, imagem 2 %32
    • Remove the loudspeaker assembly.
    • During reassembly apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Conclusão
If possible, turn on your device and test your repair before installing new adhesive and resealing.
After you've completed the repair, follow this guide to test your repair.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
Uma outra pessoa concluiu este guia.
Dominik Schnabelrauch
Membro desde: 11/23/16
206.467 Reputação
Autoria de 682 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 137
Autoria de 17.524 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 28
Últimos 30 dias: 105
Duração total: 4,289
