Ir para o conteúdo principal
Samsung Galaxy Note20 Ultra Rear Cover Replacement
O que você precisa
  1. Samsung Galaxy Note20 Ultra Rear Cover Replacement, Heat the rear cover: passo 1, imagem 1 %32
    • Completely power off your phone before you begin disassembly.
    • Heat an iOpener and apply it to the left side of the rear cover for one minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the screen and internal battery are susceptible to heat damage.
  2. Samsung Galaxy Note20 Ultra Rear Cover Replacement, Insert an opening pick: passo 2, imagem 1 %32 Samsung Galaxy Note20 Ultra Rear Cover Replacement, Insert an opening pick: passo 2, imagem 2 %32 Samsung Galaxy Note20 Ultra Rear Cover Replacement, Insert an opening pick: passo 2, imagem 3 %32
    • Apply a suction cup to the heated edge of the rear cover, as close to the edge as possible.
    • If your back glass is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken panel.
    • Pull up on the suction cup with strong, steady force to create a gap between the rear cover and the frame.
    • Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
    • Insert an opening pick into the gap.
    • Don't insert the opening pick more than 5 mm into the phone or you risk damaging the internal components.
  3. Samsung Galaxy Note20 Ultra Rear Cover Replacement, Begin to cut the adhesive: passo 3, imagem 1 %32 Samsung Galaxy Note20 Ultra Rear Cover Replacement, Begin to cut the adhesive: passo 3, imagem 2 %32 Samsung Galaxy Note20 Ultra Rear Cover Replacement, Begin to cut the adhesive: passo 3, imagem 3 %32
    • Slide the opening pick along the left edge towards the bottom left corner to cut through the adhesive.
    • Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
  4. Samsung Galaxy Note20 Ultra Rear Cover Replacement, Cut along the perimeter of the rear cover: passo 4, imagem 1 %32 Samsung Galaxy Note20 Ultra Rear Cover Replacement, Cut along the perimeter of the rear cover: passo 4, imagem 2 %32 Samsung Galaxy Note20 Ultra Rear Cover Replacement, Cut along the perimeter of the rear cover: passo 4, imagem 3 %32
    • While cutting through the adhesive, don't insert the opening pick more than 5 mm into the phone or you risk damaging the internal components.
    • Repeat the process of heating and cutting the adhesive along the three remaining sides of the rear cover.
    • You can insert each new opening pick in the gaps created by the opening picks left in each corner.
    • As you proceed, leave an opening pick in each corner to prevent the adhesive from re-sealing.
    • Slide an opening pick back and forth around the entire perimeter of the phone to release any missed adhesive. Reheat any stubborn adhesive.
  5. Samsung Galaxy Note20 Ultra Rear Cover Replacement, Remove the rear cover: passo 5, imagem 1 %32 Samsung Galaxy Note20 Ultra Rear Cover Replacement, Remove the rear cover: passo 5, imagem 2 %32
    • Lift the rear cover straight up to remove it.
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Samsung Galaxy Note20 Ultra Answers community for help.
7 outras pessoas executaram este guia.
Kyle Smith
Membro desde: 02/01/21
42.030 Reputação
Autoria de 123 guias
6 comentários
"Cover Replacement" not removal!, how do I put the new one on?!
Daniel - Responder
How to put the new back cover on?
What kind adhesive to use and where to a
David - Responder
Clean the rim of the phone off and when you get the new backplate use adhesive it came with if it did not come with adhesive. use Double-Sided High Strength Polyester Tape 300LSE (3MM x 25M) (3M Model # 9475LEB) or something similar to it(don't use liquid glue, you will mess stuff up)
ryley niemi - Responder
everything went great and everything works well. it only rattles a little. like something small is loose. I don't know if that's bad now?
I had to remove a small part from the old back and put it on the new one.
Barbara Barbarossa - Responder
So to do this in reverse you use the picks again do you heat it Last to get the adhesive to adhere????? The Title is very misleading it says replacement as far as any manuals I have seen (IE cam replacement, Head replacement (Automotive) the instructions do not stop once it is removed they have a Butt load of specific steps to reinstall the item, like Torque specs, Timing alignment )Not this to Reassemble do the steps in reverse order as this states . It should be called Removal only. Is there special glue used? What about the camera cover thing does it get attached to the rear Glass/Cover or is it attached to something internally?? No mention of that at all Very crappy Instructions to be honest
James Vining - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 14
Últimos 7 dias: 87
Últimos 30 dias: 454
Duração total: 15,883
