Introdução
Use this guide to remove the rear cover on your Samsung Galaxy Note20.
For your safety, discharge the battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
O que você precisa
Heat an iOpener and apply it to the left side of the rear cover for one minute.
Apply a suction cup to the heated edge of the rear cover, as close to the edge as possible.
Pull up on the suction cup with strong, steady force to create a gap between the rear cover and the frame.
Insert an opening pick into the gap.
Slide the opening pick along the left edge towards the bottom left corner to cut through the adhesive.
Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
Repeat the process of heating and cutting the adhesive along the three remaining sides of the rear cover.
As you proceed, leave an opening pick in each corner to prevent the adhesive from re-sealing.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Samsung Galaxy Note20 Answers community for help.
Uma outra pessoa concluiu este guia.
