Ir para o conteúdo principal
Samsung Galaxy Note10+ Earpiece Speaker Replacement
O que você precisa
  1. Samsung Galaxy Note10+ Earpiece Speaker Replacement, Remove the SIM card: passo 1, imagem 1 %32 Samsung Galaxy Note10+ Earpiece Speaker Replacement, Remove the SIM card: passo 1, imagem 2 %32 Samsung Galaxy Note10+ Earpiece Speaker Replacement, Remove the SIM card: passo 1, imagem 3 %32
    • Insert a SIM eject tool, bit, or a straightened paper clip into the small hole on the SIM card tray on the top edge of the phone.
    • Press firmly to eject the tray.
    • Remove the SIM card tray.
  2. Samsung Galaxy Note10+ Earpiece Speaker Replacement, Heat the rear cover: passo 2, imagem 1 %32
    • Completely power off your phone before you begin disassembly.
    • Prepare an iOpener and apply it to the left edge of the rear cover for one minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  3. Samsung Galaxy Note10+ Earpiece Speaker Replacement, Insert an opening pick: passo 3, imagem 1 %32 Samsung Galaxy Note10+ Earpiece Speaker Replacement, Insert an opening pick: passo 3, imagem 2 %32 Samsung Galaxy Note10+ Earpiece Speaker Replacement, Insert an opening pick: passo 3, imagem 3 %32
    • Apply a suction cup to the heated edge of the rear cover, as close to the edge as possible.
    • If your rear cover is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken cover.
    • Pull up on the suction cup with strong, steady force to create a gap between the rear cover and the frame.
    • Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
    • Insert the point of an opening pick into the gap.
  4. Samsung Galaxy Note10+ Earpiece Speaker Replacement, Begin to slice the adhesive: passo 4, imagem 1 %32 Samsung Galaxy Note10+ Earpiece Speaker Replacement, Begin to slice the adhesive: passo 4, imagem 2 %32 Samsung Galaxy Note10+ Earpiece Speaker Replacement, Begin to slice the adhesive: passo 4, imagem 3 %32
    • Slide the opening pick along the left edge towards the bottom left corner to slice the adhesive.
    • Don't insert the opening pick more than halfway into the phone or you risk damaging internal components.
    • Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
  5. Samsung Galaxy Note10+ Earpiece Speaker Replacement, Slice around the perimeter of the phone: passo 5, imagem 1 %32 Samsung Galaxy Note10+ Earpiece Speaker Replacement, Slice around the perimeter of the phone: passo 5, imagem 2 %32 Samsung Galaxy Note10+ Earpiece Speaker Replacement, Slice around the perimeter of the phone: passo 5, imagem 3 %32
    • Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
    • Leave an opening pick on each side as you continue to the next to prevent the adhesive from resealing.
    • The rear cover will begin to separate from the phone as you finish all sides of the phone.
  6. Samsung Galaxy Note10+ Earpiece Speaker Replacement, Lift off the rear cover: passo 6, imagem 1 %32 Samsung Galaxy Note10+ Earpiece Speaker Replacement, Lift off the rear cover: passo 6, imagem 2 %32
    • Lift the rear cover straight up to remove it.
    • Follow this guide to reinstall the rear cover and replace the adhesive.
    • Be sure to turn on your device and test your repair before installing new adhesive and resealing the device.
    • If you're using Tesa tape to reattach components, follow this guide.
  7. Samsung Galaxy Note10+ Earpiece Speaker Replacement, Lift up the metal cover: passo 7, imagem 1 %32
    • Use a Phillips screwdriver to remove the five 4 mm screws securing the wireless charging coil.
  8. Samsung Galaxy Note10+ Earpiece Speaker Replacement: passo 8, imagem 1 %32 Samsung Galaxy Note10+ Earpiece Speaker Replacement: passo 8, imagem 2 %32 Samsung Galaxy Note10+ Earpiece Speaker Replacement: passo 8, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Use a pair of tweezers to lift up and flip back the metal shield covering the battery connector.
  9. Samsung Galaxy Note10+ Earpiece Speaker Replacement, Disconnect the battery: passo 9, imagem 1 %32 Samsung Galaxy Note10+ Earpiece Speaker Replacement, Disconnect the battery: passo 9, imagem 2 %32
    • While holding the metal shield up and out of the way, use the pointed end of a spudger to pry up the battery connector to disconnect it.
  10. Samsung Galaxy Note10+ Earpiece Speaker Replacement, Disconnect the wireless charging coil: passo 10, imagem 1 %32 Samsung Galaxy Note10+ Earpiece Speaker Replacement, Disconnect the wireless charging coil: passo 10, imagem 2 %32
    • Use the pointed end of a spudger to disconnect the wireless charging coil connector from the motherboard.
  11. Samsung Galaxy Note10+ Earpiece Speaker Replacement, Remove the wireless charging coil: passo 11, imagem 1 %32 Samsung Galaxy Note10+ Earpiece Speaker Replacement, Remove the wireless charging coil: passo 11, imagem 2 %32 Samsung Galaxy Note10+ Earpiece Speaker Replacement, Remove the wireless charging coil: passo 11, imagem 3 %32
    • Tilt the metal shielding up so you can grip it with your fingers.
    • Peel the wireless charging coil up and away from the device.
    • The wireless charging coil is secured to the phone with some light adhesive.
    • Remove the wireless charging coil.
  12. Samsung Galaxy Note10+ Earpiece Speaker Replacement, Remove the loudspeaker screws: passo 12, imagem 1 %32
    • Use a Phillips screwdriver to remove the five 4 mm screws securing the loudspeaker.
  13. Samsung Galaxy Note10+ Earpiece Speaker Replacement, Remove the loudspeaker: passo 13, imagem 1 %32 Samsung Galaxy Note10+ Earpiece Speaker Replacement, Remove the loudspeaker: passo 13, imagem 2 %32 Samsung Galaxy Note10+ Earpiece Speaker Replacement, Remove the loudspeaker: passo 13, imagem 3 %32
    • Use a pair of tweezers to remove the loudspeaker.
  14. Samsung Galaxy Note10+ Earpiece Speaker Replacement, Remove the interconnect cables: passo 14, imagem 1 %32 Samsung Galaxy Note10+ Earpiece Speaker Replacement, Remove the interconnect cables: passo 14, imagem 2 %32 Samsung Galaxy Note10+ Earpiece Speaker Replacement, Remove the interconnect cables: passo 14, imagem 3 %32
    • Use the pointed end of a spudger to disconnect the main interconnect cable from the motherboard.
    • Disconnect the secondary interconnect cable from the motherboard.
  15. Samsung Galaxy Note10+ Earpiece Speaker Replacement: passo 15, imagem 1 %32 Samsung Galaxy Note10+ Earpiece Speaker Replacement: passo 15, imagem 2 %32 Samsung Galaxy Note10+ Earpiece Speaker Replacement: passo 15, imagem 3 %32
    • Use the pointed end of a spudger to disconnect the main interconnect cable from the daughterboard.
    • Disconnect the secondary interconnect cable from the daughterboard.
  16. Samsung Galaxy Note10+ Earpiece Speaker Replacement: passo 16, imagem 1 %32 Samsung Galaxy Note10+ Earpiece Speaker Replacement: passo 16, imagem 2 %32
    • Remove both interconnect cables.
  17. Samsung Galaxy Note10+ Earpiece Speaker Replacement, Remove the top plastic cover: passo 17, imagem 1 %32
    • Use a Phillips screwdriver to remove the four 4 mm screws securing the top plastic cover.
  18. Samsung Galaxy Note10+ Earpiece Speaker Replacement: passo 18, imagem 1 %32 Samsung Galaxy Note10+ Earpiece Speaker Replacement: passo 18, imagem 2 %32 Samsung Galaxy Note10+ Earpiece Speaker Replacement: passo 18, imagem 3 %32
    • Use a pair of tweezers to pivot the top plastic cover up and off of the phone.
  19. Samsung Galaxy Note10+ Earpiece Speaker Replacement, Disconnect motherboard connectors: passo 19, imagem 1 %32 Samsung Galaxy Note10+ Earpiece Speaker Replacement, Disconnect motherboard connectors: passo 19, imagem 2 %32 Samsung Galaxy Note10+ Earpiece Speaker Replacement, Disconnect motherboard connectors: passo 19, imagem 3 %32
    • Use the pointed end of a spudger to disconnect the touch layer connector from the motherboard.
    • Disconnect the side button connector from the motherboard.
  20. Samsung Galaxy Note10+ Earpiece Speaker Replacement: passo 20, imagem 1 %32 Samsung Galaxy Note10+ Earpiece Speaker Replacement: passo 20, imagem 2 %32
    • Use the pointed end of a spudger to disconnect the S-Pen charging coil connector from the motherboard.
  21. Samsung Galaxy Note10+ Earpiece Speaker Replacement: passo 21, imagem 1 %32 Samsung Galaxy Note10+ Earpiece Speaker Replacement: passo 21, imagem 2 %32
    • Use the pointed end of a spudger to disconnect the display cable from the motherboard.
  22. Samsung Galaxy Note10+ Earpiece Speaker Replacement, Remove the motherboard: passo 22, imagem 1 %32 Samsung Galaxy Note10+ Earpiece Speaker Replacement, Remove the motherboard: passo 22, imagem 2 %32 Samsung Galaxy Note10+ Earpiece Speaker Replacement, Remove the motherboard: passo 22, imagem 3 %32
    • Use the pointed end of a spudger to pry up the motherboard enough to grip it with your fingers.
    • Remove the motherboard.
  23. Samsung Galaxy Note10+ Earpiece Speaker Replacement, Remove the earpiece speaker: passo 23, imagem 1 %32 Samsung Galaxy Note10+ Earpiece Speaker Replacement, Remove the earpiece speaker: passo 23, imagem 2 %32 Samsung Galaxy Note10+ Earpiece Speaker Replacement, Remove the earpiece speaker: passo 23, imagem 3 %32
    • Insert the pointed end of a spudger in the gap between the earpiece speaker and the phone's frame, near the bottom left corner of the speaker.
    • Pry up to loosen the earpiece speaker from its recess.
    • The earpiece speaker is secured with light adhesive.
  24. Samsung Galaxy Note10+ Earpiece Speaker Replacement: passo 24, imagem 1 %32 Samsung Galaxy Note10+ Earpiece Speaker Replacement: passo 24, imagem 2 %32 Samsung Galaxy Note10+ Earpiece Speaker Replacement: passo 24, imagem 3 %32
    • Use a pair of tweezers to lift the earpiece speaker out of its recess and remove it.
    • Make sure to remove any old adhesive before you replace the earpiece speaker.
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
3 outras pessoas executaram este guia.
Carsten Frauenheim
Membro desde: 03/10/20
155.310 Reputação
Autoria de 439 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 23.608 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 42
Ao todo: 3,315
