Ir para o conteúdo principal
Samsung Galaxy A52 Battery Replacement
O que você precisa
  1. Samsung Galaxy A52 Battery Replacement, Heat the back cover: passo 1, imagem 1 %32
    • Prepare an iOpener and apply it to the back cover for at least two minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Samsung Galaxy A52 Battery Replacement, Insert an opening pick: passo 2, imagem 1 %32 Samsung Galaxy A52 Battery Replacement, Insert an opening pick: passo 2, imagem 2 %32
    • Secure a suction handle to the right edge of the back cover, as close to the edge as possible.
    • If the back cover is damaged, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the back cover with the suction handle to create a small gap between the back cover and the frame.
    • In case you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap you created.
  3. Samsung Galaxy A52 Battery Replacement, Slice the adhesive: passo 3, imagem 1 %32 Samsung Galaxy A52 Battery Replacement, Slice the adhesive: passo 3, imagem 2 %32
    • Slide the opening pick to the top right corner to slice the adhesive.
    • Leave the opening pick in its place to prevent the adhesive from resealing.
  4. Samsung Galaxy A52 Battery Replacement: passo 4, imagem 1 %32 Samsung Galaxy A52 Battery Replacement: passo 4, imagem 2 %32 Samsung Galaxy A52 Battery Replacement: passo 4, imagem 3 %32
    • Insert a second opening pick underneath the top right edge of your phone.
    • Slide the opening pick to the bottom right corner to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  5. Samsung Galaxy A52 Battery Replacement: passo 5, imagem 1 %32 Samsung Galaxy A52 Battery Replacement: passo 5, imagem 2 %32
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener to reheat it.
    • Insert a third opening pick at the bottom edge of your phone.
    • Slide the opening pick along the bottom edge of your phone to slice the adhesive.
    • Leave the opening pick in the bottom left corner to prevent the adhesive from resealing.
  6. Samsung Galaxy A52 Battery Replacement: passo 6, imagem 1 %32 Samsung Galaxy A52 Battery Replacement: passo 6, imagem 2 %32 Samsung Galaxy A52 Battery Replacement: passo 6, imagem 3 %32
    • Insert a fourth opening pick underneath the bottom left corner of your phone.
    • Slide the opening pick along the left edge to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  7. Samsung Galaxy A52 Battery Replacement: passo 7, imagem 1 %32 Samsung Galaxy A52 Battery Replacement: passo 7, imagem 2 %32
    • Insert a fifth opening pick underneath the top left corner.
    • Slide the opening pick along the top edge of the back cover to slice the remaining adhesive.
  8. Samsung Galaxy A52 Battery Replacement, Remove the back cover: passo 8, imagem 1 %32
    • Remove the back cover.
    • Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • Secure the new back cover with pre-cut adhesive or double-sided adhesive tape. After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
  9. Samsung Galaxy A52 Battery Replacement, Unscrew the motherboard cover: passo 9, imagem 1 %32
    • Use a Phillips screwdriver to remove the ten 4.4 mm-long screws securing the motherboard cover.
  10. Samsung Galaxy A52 Battery Replacement, Pry up the motherboard cover: passo 10, imagem 1 %32 Samsung Galaxy A52 Battery Replacement, Pry up the motherboard cover: passo 10, imagem 2 %32 Samsung Galaxy A52 Battery Replacement, Pry up the motherboard cover: passo 10, imagem 3 %32
    • Insert an opening pick underneath the left edge of the motherboard cover.
    • Use the opening pick to pry up the motherboard cover.
    • Remove the motherboard cover.
  11. Samsung Galaxy A52 Battery Replacement, Disconnect the battery: passo 11, imagem 1 %32 Samsung Galaxy A52 Battery Replacement, Disconnect the battery: passo 11, imagem 2 %32
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
  12. Samsung Galaxy A52 Battery Replacement, Disconnect the interconnect cable: passo 12, imagem 1 %32 Samsung Galaxy A52 Battery Replacement, Disconnect the interconnect cable: passo 12, imagem 2 %32
    • Use the flat end of a spudger to pry up and disconnect the interconnect cable from its socket.
  13. Samsung Galaxy A52 Battery Replacement, Free the battery: passo 13, imagem 1 %32 Samsung Galaxy A52 Battery Replacement, Free the battery: passo 13, imagem 2 %32
    • During the following step do not fold the cable sharply and only bend it to avoid damaging the cable.
    • Bend the interconnect flex cable towards the charging port in order to get free access to the battery.
    • You might want to use a small piece of tape to temporarily stick the cable onto your working surface to avoid accidentally damaging it during the battery removal.
  14. Samsung Galaxy A52 Battery Replacement, Apply adhesive remover: passo 14, imagem 1 %32
    • Follow these preparation steps before using adhesive remover.
    • Apply a few drops of adhesive remover or high-concentration (90% or higher) isopropyl alcohol into the gap at the left edge of the battery.
    • Tilt the phone in an 45 degree angle to let spread the isopropyl alcohol evenly underneath the battery.
    • Let the adhesive remover penetrate the battery adhesive for at least 1 minute.
  15. Samsung Galaxy A52 Battery Replacement, Pry up the battery: passo 15, imagem 1 %32 Samsung Galaxy A52 Battery Replacement, Pry up the battery: passo 15, imagem 2 %32 Samsung Galaxy A52 Battery Replacement, Pry up the battery: passo 15, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Plastic Cards
    $2.99
    Comprar
    • For this step, insert a plastic card into the edge with a wider gap between the midframe and the battery so that you have more space for the plastic card and get a better leverage.
    • Carefully slide it underneath the battery to loosen the adhesive.
    • Slide the plastic card underneath and pry up the battery from its recess.
    • The battery should come off easily. In case the battery is still sticky, repeat the previous adhesive remover procedure or use an iOpener to further soften the battery adhesive.
  16. Samsung Galaxy A52 Battery Replacement, Remove the battery: passo 16, imagem 1 %32
    • Remove the battery.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • Before installing a new battery remove any remaining adhesive, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
    • During reassembly, follow this guide if you're using a pre-cut adhesive card.
    • If there's any alcohol solution remaining in the phone, carefully wipe it off or allow it to air dry before installing your new battery.
    • During reassembly, temporarily reconnect the battery to the motherboard to help align it correctly. Disconnect the battery after it is seated.
Conclusão
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
12 outras pessoas executaram este guia.
Adriana Zwink
Membro desde: 12/18/19
48.633 Reputação
Autoria de 167 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 136
Autoria de 17.303 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 43
Últimos 7 dias: 311
Últimos 30 dias: 1,458
Duração total: 25,095
