Ir para o conteúdo principal
Ryobi CSB125 Trigger Replacement
O que você precisa
    1. Ryobi CSB125 Trigger Replacement, Trigger: passo 1, imagem 1 %32
      • Place the saw down on a flat surface with the motor facing up.
      • Make sure that the saw is unplugged from any power source.
      Pergunte ao FixBot
      Comentar
    2. Ryobi CSB125 Trigger Replacement: passo 2, imagem 1 %32 Ryobi CSB125 Trigger Replacement: passo 2, imagem 2 %32
      • Use the Phillips #2 screwdriver to remove the five M4x16mm screws.
      Pergunte ao FixBot
      Comentar
    3. Ryobi CSB125 Trigger Replacement: passo 3, imagem 1 %32
      • Use the Phillips #2 screwdriver to remove the two M45x35mm screws.
      Pergunte ao FixBot
      Comentar
    4. Ryobi CSB125 Trigger Replacement: passo 4, imagem 1 %32
      • Disconnect the two black wires by unscrewing them from the trigger switch using the Phillips #2 screwdriver.
      Pergunte ao FixBot
      Comentar
    5. Ryobi CSB125 Trigger Replacement: passo 5, imagem 1 %32
      • Remove the trigger from the saw.
      • You may have to use the wire strippers to the copper on the new plug.
      • It is important that the wires are properly run in their tracks. Failure to do so could result in pinching a wire, which could damage the plug.
      Pergunte ao FixBot
      Comentar
Conclusão
3 outras pessoas executaram este guia.
Curtis Melo
Membro desde: 10/31/19
1.093 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team S2-G1, Barthe Fall 2019 Membro de UMass Dartmouth, Team S2-G1, Barthe Fall 2019
UMASSD-BARTHE-F19S2G1
3 Membros
Autoria de 25 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 30
Ao todo: 911
