Ir para o conteúdo principal
Ryobi CSB125 Protective Shell Replacement
O que você precisa
    1. Ryobi CSB125 Protective Shell Replacement, Protective Shell: passo 1, imagem 1 %32
      • Place the saw on a flat surface with the blade facing up.
      • Make sure that the saw is unplugged from any power source.
      Pergunte ao FixBot
      Comentar
    2. Ryobi CSB125 Protective Shell Replacement: passo 2, imagem 1 %32
      • Remove the bumper by using the T20 Torx screwdriver to loosen the M5 x 20mm screw.
      Pergunte ao FixBot
      Comentar
    3. Ryobi CSB125 Protective Shell Replacement: passo 3, imagem 1 %32 Ryobi CSB125 Protective Shell Replacement: passo 3, imagem 2 %32
      • Use the 7”/32 allen key to loosen the 5/16-18 x 9/16 in. blade screw.
      Pergunte ao FixBot
      Comentar
    4. Ryobi CSB125 Protective Shell Replacement: passo 4, imagem 1 %32
      • Remove the 5/16-18 x 9/16 in. blade screw, spring washer, the outer blade washer, the blade, and the inner blade washer.
      Pergunte ao FixBot
      Comentar
    5. Ryobi CSB125 Protective Shell Replacement: passo 5, imagem 1 %32 Ryobi CSB125 Protective Shell Replacement: passo 5, imagem 2 %32 Ryobi CSB125 Protective Shell Replacement: passo 5, imagem 3 %32
      • Use the Phillips #2 screwdriver to remove the four M4x16mm screws shown.
      • You will need to rotate the protective shell around in order to access them.
      Pergunte ao FixBot
      Comentar
    6. Ryobi CSB125 Protective Shell Replacement: passo 6, imagem 1 %32
      • Remove the lower blade guard support assembly from the rest of the saw.
      • Remove the protective shell.
      Pergunte ao FixBot
      Comentar
Conclusão
4 outras pessoas executaram este guia.
Curtis Melo
Membro desde: 10/31/19
1.093 Reputação
Autoria de 5 guias
Equipe
4Comentários do guia
Instructions fail at step #5. Bottom-left screw is under the plastic blade guard which blocks removal of the screw. Blade guard covers the screw no matter how it’s positioned.
Michael Bluejay - Responder Compartilhar
If you wiggle the plastic you can remove
I was able to remove… be patient it does work
Adrian Isbister - Responder Compartilhar
Instructions also fail at step #6. I have no idea how to remove the plastic blade guard from the axle so I can transfer it to the new (replacement) blade guard.
I also was struggling… … but if you look closely there is a thin metal ring around the center plastic ring that the spindle runs through… this has a split in it…. I used a small flat Precision screwdriver (type used to tighten reading glasses,etc)and was able to pry at the split and remove the thin metal ring.
Once removed this frees the plastic guard and it drops right out.
Just reverse to reassemble.
This works… just be patient
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 12
Últimos 30 dias: 36
Ao todo: 2,835
