Ir para o conteúdo principal
Ryobi CSB125 Motor Replacement
O que você precisa
    1. Ryobi CSB125 Motor Replacement, Motor: passo 1, imagem 1 %32
      • Place the saw on a flat surface with the blade facing up.
      • Make sure that the saw is unplugged from any power source.
      Pergunte ao FixBot
      Comentar
    2. Ryobi CSB125 Motor Replacement: passo 2, imagem 1 %32 Ryobi CSB125 Motor Replacement: passo 2, imagem 2 %32
      • Remove the bumper by using the T20 torx screwdriver to loosen the M5 x 20mm screw.
      Pergunte ao FixBot
      Comentar
    3. Ryobi CSB125 Motor Replacement: passo 3, imagem 1 %32 Ryobi CSB125 Motor Replacement: passo 3, imagem 2 %32
      • Use the 7”/32 allen key to loosen the 5/16-18 x 9/16 in. blade screw.
      Pergunte ao FixBot
      Comentar
    4. Ryobi CSB125 Motor Replacement: passo 4, imagem 1 %32
      • Remove the 5/16-18 x 9/16 in. blade screw, spring washer, the outer blade washer, the blade, and the inner blade washer.
      Pergunte ao FixBot
      Comentar
    5. Ryobi CSB125 Motor Replacement: passo 5, imagem 1 %32 Ryobi CSB125 Motor Replacement: passo 5, imagem 2 %32 Ryobi CSB125 Motor Replacement: passo 5, imagem 3 %32
      • Use the #2 Phillip screwdriver to remove the four M4x16mm screws shown.
      • You will need to rotate the protective shell around in order to access them.
      Pergunte ao FixBot
      Comentar
    6. Ryobi CSB125 Motor Replacement: passo 6, imagem 1 %32
      • Remove the lower blade guard support assembly from the rest of the saw.
      Pergunte ao FixBot
      Comentar
    7. Ryobi CSB125 Motor Replacement: passo 7, imagem 1 %32
      • Flip the saw over and place the saw down on a flat surface with the motor facing up.
      Pergunte ao FixBot
      Comentar
    8. Ryobi CSB125 Motor Replacement: passo 8, imagem 1 %32
      • Use the Phillips #2 screwdriver to remove the five M4x16mm screws.
      Pergunte ao FixBot
      Comentar
    9. Ryobi CSB125 Motor Replacement: passo 9, imagem 1 %32
      • Use the Phillips #2 screwdriver to remove the two M45x35mm screws.
      Pergunte ao FixBot
      Comentar
    10. Ryobi CSB125 Motor Replacement: passo 10, imagem 1 %32 Ryobi CSB125 Motor Replacement: passo 10, imagem 2 %32
      • Use the Phillips #2 screwdriver to remove the two M4x16mm screws holding down the end cover.
      • Pull off the end cover.
      Pergunte ao FixBot
      Comentar
    11. Ryobi CSB125 Motor Replacement: passo 11, imagem 1 %32
      • Use the Phillips #2 screwdriver to remove the M45x35mm screw holding down the motor housing.
      Pergunte ao FixBot
      Comentar
    12. Ryobi CSB125 Motor Replacement: passo 12, imagem 1 %32
      • Remove the motor housing for access to the internal motor components.
      Pergunte ao FixBot
      Comentar
Conclusão
3 outras pessoas executaram este guia.
Curtis Melo
Membro desde: 10/31/19
1.093 Reputação
Autoria de 5 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 41
Ao todo: 1,177
