Ir para o conteúdo principal
Rexing V1P Plus Screen Replacement
O que você precisa
    1. Rexing V1P Plus Screen Replacement, Front Camera: passo 1, imagem 1 %32 Rexing V1P Plus Screen Replacement, Front Camera: passo 1, imagem 2 %32 Rexing V1P Plus Screen Replacement, Front Camera: passo 1, imagem 3 %32
      • Begin by orienting the device with the LCD screen facing down.
      • Remove the four 6 mm screws, located on the backside of the device, using the Phillips #00 screwdriver.
      Pergunte ao FixBot
      Comentar
    2. Rexing V1P Plus Screen Replacement: passo 2, imagem 1 %32 Rexing V1P Plus Screen Replacement: passo 2, imagem 2 %32 Rexing V1P Plus Screen Replacement: passo 2, imagem 3 %32
      • Remove the back cover of the device and place it to the side.
      • Rotate the device 180 degrees to where the camera is facing you.
      Pergunte ao FixBot
      Comentar
    3. Rexing V1P Plus Screen Replacement: passo 3, imagem 1 %32 Rexing V1P Plus Screen Replacement: passo 3, imagem 2 %32 Rexing V1P Plus Screen Replacement: passo 3, imagem 3 %32
      • Remove the two 5 mm screws next to the lens using the Phillips #00 screwdriver.
      Pergunte ao FixBot
      Comentar
    4. Rexing V1P Plus Screen Replacement: passo 4, imagem 1 %32 Rexing V1P Plus Screen Replacement: passo 4, imagem 2 %32 Rexing V1P Plus Screen Replacement: passo 4, imagem 3 %32
      • Remove the two camera angle adjusters from the side of the device and carefully pull out the lens.
      Pergunte ao FixBot
      Comentar
    5. Rexing V1P Plus Screen Replacement: passo 5, imagem 1 %32 Rexing V1P Plus Screen Replacement: passo 5, imagem 2 %32 Rexing V1P Plus Screen Replacement: passo 5, imagem 3 %32
      • Remove the two 5mm screws securing the camera support bracket using the Phillips #00 screwdriver.
      Pergunte ao FixBot
      Comentar
    6. Rexing V1P Plus Screen Replacement: passo 6, imagem 1 %32 Rexing V1P Plus Screen Replacement: passo 6, imagem 2 %32 Rexing V1P Plus Screen Replacement: passo 6, imagem 3 %32
      • Carefully remove the plastic frame piece from its previously secured position on the motherboard.
      • It will rest loosely around the white camera ribbon.
      • Rotate the device 180 degrees to where the camera is facing away from you.
      Pergunte ao FixBot
      Comentar
    7. Rexing V1P Plus Screen Replacement: passo 7, imagem 1 %32 Rexing V1P Plus Screen Replacement: passo 7, imagem 2 %32 Rexing V1P Plus Screen Replacement: passo 7, imagem 3 %32
      • Carefully peel back the adhesive material covering the ribbon cable connection.
      Pergunte ao FixBot
      Comentar
    8. Rexing V1P Plus Screen Replacement: passo 8, imagem 1 %32 Rexing V1P Plus Screen Replacement: passo 8, imagem 2 %32 Rexing V1P Plus Screen Replacement: passo 8, imagem 3 %32
      • Using the Flathead 1.5mm screwdriver, or another pry tool, gently flip up the black ZIF connector locking flap to free the ribbon cable.
      • Once the connector is open, slide the ribbon cable out to remove it.
      Pergunte ao FixBot
      Comentar
    1. Rexing V1P Plus Screen Replacement, Motherboard: passo 9, imagem 1 %32 Rexing V1P Plus Screen Replacement, Motherboard: passo 9, imagem 2 %32 Rexing V1P Plus Screen Replacement, Motherboard: passo 9, imagem 3 %32
      • Using a soldering iron, disconnect the four wires connected to the motherboard.
      Pergunte ao FixBot
      Comentar
    2. Rexing V1P Plus Screen Replacement: passo 10, imagem 1 %32 Rexing V1P Plus Screen Replacement: passo 10, imagem 2 %32 Rexing V1P Plus Screen Replacement: passo 10, imagem 3 %32
      • Using the Phillips #00 screwdriver, remove the three 3.5 mm screws securing the motherboard to the case.
      Pergunte ao FixBot
      Comentar
    3. Rexing V1P Plus Screen Replacement: passo 11, imagem 1 %32 Rexing V1P Plus Screen Replacement: passo 11, imagem 2 %32 Rexing V1P Plus Screen Replacement: passo 11, imagem 3 %32
      • Pull the black antenna wire with the gold cap straight up to disconnect it from the motherboard.
      • Using your fingers, spread the case apart to provide space for the motherboard to be removed.
      • This must be done to free the connected ports from their mounting locations in the case.
      Pergunte ao FixBot
      Comentar
    1. Rexing V1P Plus Screen Replacement, Screen: passo 12, imagem 1 %32 Rexing V1P Plus Screen Replacement, Screen: passo 12, imagem 2 %32
      • Once separated from the case, flip the motherboard over so the screen faces upward.
      • Rotate the motherboard so that the screen hangs over the top of the motherboard, as seen in the second image.
      Pergunte ao FixBot
      Comentar
    2. Rexing V1P Plus Screen Replacement: passo 13, imagem 1 %32 Rexing V1P Plus Screen Replacement: passo 13, imagem 2 %32 Rexing V1P Plus Screen Replacement: passo 13, imagem 3 %32
      • Using the Flathead 1.5mm screwdriver, flip up the black ZIF connector locking flap to free the ribbon cable.
      • Slide the ribbon cable out to remove it.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
1Comentário do guia
Where do I find the replacement screen?
Cesar Perez - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 27
Ao todo: 429
