Ir para o conteúdo principal
RetroMini Miyoo Mini Plus Battery Replacement
O que você precisa
  1. RetroMini Miyoo Mini Plus Battery Replacement, Battery: passo 1, imagem 1 %32 RetroMini Miyoo Mini Plus Battery Replacement, Battery: passo 1, imagem 2 %32
    • Lay the device face down on a flat surface.
    • You may want to lay the device on a towel or other soft surface to avoid scratching the screen.
  2. RetroMini Miyoo Mini Plus Battery Replacement: passo 2, imagem 1 %32 RetroMini Miyoo Mini Plus Battery Replacement: passo 2, imagem 2 %32
    • Use your fingernail to push in the battery compartment tab.
    • Lift the cover up to expose the battery.
  3. RetroMini Miyoo Mini Plus Battery Replacement: passo 3, imagem 1 %32
    • Use an opening tool to gently lift the the battery from its compartment.
    • Gently pull the battery out and set the battery next to the system, with care not to strain the attached wire.
  4. RetroMini Miyoo Mini Plus Battery Replacement: passo 4, imagem 1 %32 RetroMini Miyoo Mini Plus Battery Replacement: passo 4, imagem 2 %32
    • Pinch the white battery connector and pull it directly out of its socket.
    • Completely remove the battery.
  5. RetroMini Miyoo Mini Plus Battery Replacement: passo 5, imagem 1 %32 RetroMini Miyoo Mini Plus Battery Replacement: passo 5, imagem 2 %32
    • When you have the new battery, put the new battery wire into the connecter.
    • Place the battery back into the empty space with the wire at the bottom of the battery.
Conclusão
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Steam Deck answers community for help.
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 36
Últimos 30 dias: 151
Ao todo: 679
