Ir para o conteúdo principal
Retro-Bit Retro Duo Reset Button/Power Switch Replacement
O que você precisa
  1. Retro-Bit Retro Duo Reset Button/Power Switch Replacement, Reset Button/Power Switch: passo 1, imagem 1 %32 Retro-Bit Retro Duo Reset Button/Power Switch Replacement, Reset Button/Power Switch: passo 1, imagem 2 %32 Retro-Bit Retro Duo Reset Button/Power Switch Replacement, Reset Button/Power Switch: passo 1, imagem 3 %32
    • With the console on its top. Remove the four 12 mm Phillips #2 screws.
    • There may be a sticker covering one, or more, of the screws. Simply remove the it before the screws.
    • Flip the console on its feet and carefully lift the top casing from the back (where the AV/S and power ports are).
    • To avoid damage, do not completely remove the top case. There is a small circuit board--which houses two LEDs-- connected to the main circuit board.
    Pergunte ao FixBot
    Comentar
  2. Retro-Bit Retro Duo Reset Button/Power Switch Replacement: passo 2, imagem 1 %32 Retro-Bit Retro Duo Reset Button/Power Switch Replacement: passo 2, imagem 2 %32 Retro-Bit Retro Duo Reset Button/Power Switch Replacement: passo 2, imagem 3 %32
    • Remove the one 6 mm Phillips #0 screw.
    • Lift the top case.
    • This step allows easy button access and prevents accidental damage.
    Pergunte ao FixBot
    Comentar
  3. Retro-Bit Retro Duo Reset Button/Power Switch Replacement: passo 3, imagem 1 %32 Retro-Bit Retro Duo Reset Button/Power Switch Replacement: passo 3, imagem 2 %32 Retro-Bit Retro Duo Reset Button/Power Switch Replacement: passo 3, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Using your fingers (or precision tweezers), carefully pinch the button tabs and push through to the other side.
    • Make sure you pinch both tabs simultaneously, or the button will not pop out.
    Pergunte ao FixBot
    Comentar
Conclusão
If the problem persists after the buttons are replaced, it may be a circuit board issue. If so, please visit our guide for circuit board replacement at Retro-Bit Retro Duo Circuit Board Replacement
Truong Vo
Membro desde: 09/25/17
324 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team S4-G4, Eyestone Fall 2017 Membro de USF Tampa, Team S4-G4, Eyestone Fall 2017
USFT-EYESTONE-F17S4G4
3 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 49
Ao todo: 1,252
