Ir para o conteúdo principal
Retro-Bit Retro Duo Circuit Board Replacement
O que você precisa
  1. Retro-Bit Retro Duo Circuit Board Replacement, Circuit Board: passo 1, imagem 1 %32 Retro-Bit Retro Duo Circuit Board Replacement, Circuit Board: passo 1, imagem 2 %32 Retro-Bit Retro Duo Circuit Board Replacement, Circuit Board: passo 1, imagem 3 %32
    • With the console on its top, remove the four 12 mm Phillips #2 screws.
    • There may be a sticker covering one or more of the screws. Simply remove the sticker before screw removal.
    • Flip the console on its feet. Carefully lift the top casing from the back (where the AV/S and power ports are).
    • To avoid damage, do not remove the top casing completely. There is a small LED circuit board connected to the main circuit board.
    Pergunte ao FixBot
    Comentar
  2. Retro-Bit Retro Duo Circuit Board Replacement: passo 2, imagem 1 %32 Retro-Bit Retro Duo Circuit Board Replacement: passo 2, imagem 2 %32 Retro-Bit Retro Duo Circuit Board Replacement: passo 2, imagem 3 %32
    • Remove the one 6 mm Phillips #0 LED circuit board screw.
    • Lift the top case and set aside.
    Pergunte ao FixBot
    Comentar
  3. Retro-Bit Retro Duo Circuit Board Replacement: passo 3, imagem 1 %32 Retro-Bit Retro Duo Circuit Board Replacement: passo 3, imagem 2 %32 Retro-Bit Retro Duo Circuit Board Replacement: passo 3, imagem 3 %32
    • Remove the 11 screws holding the circuit boards and ports in place.
    • Six 11 mm Phillips #2 holding the circuit boards.
    • Three 12 mm Phillips #2 screws holding the controller ports.
    • Two 7 mm Philllips #2 screws holding the back ports
    Pergunte ao FixBot
    Comentar
  4. Retro-Bit Retro Duo Circuit Board Replacement: passo 4, imagem 1 %32 Retro-Bit Retro Duo Circuit Board Replacement: passo 4, imagem 2 %32 Retro-Bit Retro Duo Circuit Board Replacement: passo 4, imagem 3 %32
    • Carefully lift the circuit board while holding either the AV or controller ports. Alternatively, you can hold the circuit board on its edges.
    • Make sure to lift the circuit board completely out of the bottom case.
    • To avoid damage, do not to touch the top or bottom faces of the circuit board.
    Pergunte ao FixBot
    Comentar
Conclusão
Truong Vo
Membro desde: 09/25/17
324 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team S4-G4, Eyestone Fall 2017 Membro de USF Tampa, Team S4-G4, Eyestone Fall 2017
USFT-EYESTONE-F17S4G4
3 Membros
Autoria de 10 guias
1Comentário do guia
I hope you show the second part were you replace the 72pin connector. Please include part source.
The 72 pin connector grabs too tightly on the cart.
Thanks.
George Tedrick - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 50
Ao todo: 3,220
