Ir para o conteúdo principal
Repairing Samsung P241 Laser
O que você precisa
  1. Repairing Samsung P241 Laser, Top Case: passo 1, imagem 1 %32 Repairing Samsung P241 Laser, Top Case: passo 1, imagem 2 %32
    • You will need to be near a power source for this guide.
    • With the back of the DVD player facing you, remove the three 1 cm black screws on the right, left, and top sides using a Phillips #1 screwdriver.
    Pergunte ao FixBot
    Comentar
  2. Repairing Samsung P241 Laser: passo 2, imagem 1 %32 Repairing Samsung P241 Laser: passo 2, imagem 2 %32
    • Pull the top cover towards you until you can lift it up and off.
    Pergunte ao FixBot
    Comentar
  3. Repairing Samsung P241 Laser, Front Panel: passo 3, imagem 1 %32 Repairing Samsung P241 Laser, Front Panel: passo 3, imagem 2 %32
    • With the front of the DVD player facing you, turn the power on and eject the disc tray.
    • Press down on the disc tray with your thumbs while also pressing up with your pointer finger on the left and right edges of the silver cover. The cover should easily pop up and off the disc tray.
    • Be careful not to crack or bend the disc tray by pulling too hard.
    Pergunte ao FixBot
    Comentar
  4. Repairing Samsung P241 Laser: passo 4, imagem 1 %32 Repairing Samsung P241 Laser: passo 4, imagem 2 %32 Repairing Samsung P241 Laser: passo 4, imagem 3 %32
    • To remove the front panel, lift up the clips on the bottom, left and right sides of the DVD player.
    • Be sure to have all clips lifted up at the same time otherwise it will be difficult to get the panel off.
    • If you are having trouble removing the panel, try wedging an object underneath the two clips on the bottom to keep them from falling back into place.
    Pergunte ao FixBot
    Comentar
  5. Repairing Samsung P241 Laser: passo 5, imagem 1 %32
    • Gently remove the front panel by pulling it forward.
    Pergunte ao FixBot
    Comentar
  6. Repairing Samsung P241 Laser: passo 6, imagem 1 %32
    • Press the eject button again to make the disc tray slide back into place.
    • Turn off the DVD player and unplug it from the wall before proceeding to further steps.
    Pergunte ao FixBot
    Comentar
  7. Repairing Samsung P241 Laser, Repairing Samsung P241 Laser: passo 7, imagem 1 %32 Repairing Samsung P241 Laser, Repairing Samsung P241 Laser: passo 7, imagem 2 %32
    • Remove the two white ribbon cables that connect the motherboard and the disc tray by pulling on the ribbon cable where it attaches to the circuit board.
    Pergunte ao FixBot
    Comentar
  8. Repairing Samsung P241 Laser: passo 8, imagem 1 %32 Repairing Samsung P241 Laser: passo 8, imagem 2 %32 Repairing Samsung P241 Laser: passo 8, imagem 3 %32
    • Remove the three 0.6 cm gold screws holding the disc tray to the bottom casing with a Philips #1 screwdriver.
    • Lift the disc tray out.
    Pergunte ao FixBot
    Comentar
  9. Repairing Samsung P241 Laser: passo 9, imagem 1 %32 Repairing Samsung P241 Laser: passo 9, imagem 2 %32 Repairing Samsung P241 Laser: passo 9, imagem 3 %32
    • Remove the top cover of the disc tray by gently prying the clips off with a flathead screwdriver.
    • You will want to release one side before moving on to the other side, but do not lift the cover off until both sides are released.
    Pergunte ao FixBot
    Comentar
  10. Repairing Samsung P241 Laser: passo 10, imagem 1 %32 Repairing Samsung P241 Laser: passo 10, imagem 2 %32 Repairing Samsung P241 Laser: passo 10, imagem 3 %32
    • Very gently wipe the laser down with lens cleaner.
    • Be very careful that no excess cleaner drips down into the disc drive.
    • Use extreme caution when wiping the laser to avoid damaging it. If too much force is used, it will break or be pushed off-center and will not read the disc properly.
    Pergunte ao FixBot
    Comentar
Conclusão
Alexander Roberts
Membro desde: 01/04/11
101 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 14-7, Forte Winter 2011 Membro de Cal Poly, Team 14-7, Forte Winter 2011
CPSU-FORTE-W11S14G7
5 Membros
Autoria de 7 guias
2Comentários do guia
This was a terrific explanation. Our DVD player suddenly began acting up - wouldn't read DVD, wouldn't eject DVD, etc. I used these steps shown above to open up the DVD player and discovered daughter had put two DVDs in at the same time. I was able to remove the 'extra' DVD ha ha and now it works great. Thanks so much for your work to put up this overview on how to open up the case.
Dave F in Missouri - Responder Compartilhar
My laser is no good. I took it out but can't seem to find a replacement. I searched it online, but no luck. Any idea how to find a new one? I heard that a new one costs as much as just getting a new DVD player.
Ltl Paa - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 43
Ao todo: 2,790
